This project is a test basis for implementing Flexure Joints, Compliant Mechanisms, Snap Fits, and Lean Design. Many features are yet to be implemented.
With this project, we try to make a jump from Hackaday projects into Hackaday products, by obliviating the hours-long assembly and coding with incomplete manuals for users. We do this by making assembly as easy as assembling IKEA furniture, and software as easy as accidentally installing viruses.
Mostly through combining COTS and additive manufactured puzzle pieces. COTS are commercial off-the-shelf components for example a: stepper motor, bolts, nuts, bearings, and electronics. The puzzle pieces are the additive manufactured parts that are used to provide support and functionality for COTS. With this accessible way of starting a print, ordering parts, assembling, installing software, and Voila a working product.
https://www.beautiful.ai/player/-MmV1BXsRjrBKEntnWvh
Files
AAA.STEP
I know these files are not adaptable. I wan't to make the design good for anyone without need to adapt it. Therefor the design are in this format until further notice
For now, only 2 axes are incorporated. Eventually 4/6 axes will be implemtned in the design. for electronics used a Arduino uno with standard example sketch Knob only edited for two analog and to pwm channels. With 5V powering the board and servo's
