​3D Printing Custom Part for Solution #1: ADAS - CAS
A project log for Multi-Domain Depth AI Usecases on the Edge
SLAM, ADAS-CAS, Sensor Fusion, Touch-less Attendance, Elderly Assist, Monocular Depth, Gesture & Security Cam with OpenVINO, Math & RPi
anand-uthamanAnand Uthaman 10/24/2021 at 14:390 Comments
For Solution #1: ADAS - Collision Avoidance System (CAS):
For the need of assembly, a LIDAR mount had to be 3D printed so that RPi can be attached to LIDAR and mounted on a car. Part of the mount design is taken from the STL files obtained from here. The design file is attached along with the files so that you can easily rebuild the project. 3D Printing of this custom part is the first step done before doing the physical assembly.
        STL Visualization: LIDAR Mount for Raspberry Pi
Note that this solution is a sequel to my project "Self Driving Car on Indian Roads" (Blog here)
