fiberlamp.stlThis is v2, which is smaller, but doesn't require cutting the LED strip into 4 segments. The strip wraps around the model seamlessly. Corners are really close together. The other model is nicer, but trickier to put together.Standard Tesselated Geometry - 609.85 kB - 02/14/2023 at 12:46 |
Standard Tesselated Geometry - 19.61 kB - 02/14/2023 at 12:46 |
FiberlampInner.stlInner part of lampStandard Tesselated Geometry - 216.10 kB - 10/25/2021 at 00:04 |
FiberlampOuter.stlOuter part of lampStandard Tesselated Geometry - 15.71 kB - 10/25/2021 at 00:04 |
