The Levels of Hell: Dante's Inferno 2.0
Like the Sorting Hat from Harry Potter, you are judged and assigned to your own Level of Hell!
This year the theme at The Magic Castle® in Hollywood, CA was "Dante's Inferno 2.0". My team & I wanted to come up with something fun, and over-the-top whacky for Castle guests to play with and we came up with this crazy thing.
Video later in the description, and also here:
https://youtu.be/WDh4aQgI8xk
I was inspired by those "love tester" games that were popular in the 1930s-60s in arcades everywhere.
I wanted to do something along these lines but I only had a few weeks' time and my wood-working skills were no where close to being able to make a Victorian-style cabinet.  I kept looking at other love-tester designs (there are many!) and I happened across a more modern-looking one:
Even though a Victorian-style cabinet would better fit the overall aesthetic of The Magic Castle, I liked a lot of features of this one, specifically its bold use of color, the thermometer-like "readout", and the little illustrations.  This part of the love tester reminded me of the panel that has the readouts on a pinball game... a plan was forming, one that I thought I could actually make in time for the opening of Halloween Week at the Castle..  Why not update the "love tester" idea to something really modern, like a video arcade cabinet?  I knew I could buy precut kits from various online companies, and if I farmed out the artwork too then I could focus on the electronics and figure out how to fabricate it... Time to contact my friend Jeremy Owen, a comic book artist in the bear community, and see if he was up to take on a commission to do some illustrations and design these graphics.
Dante Lid Revised even more final.stl
Standard Tesselated Geometry - 2.97 MB - 10/29/2021 at 03:25
Download
Dante Nameplate 3x (1).stl
Standard Tesselated Geometry - 2.04 MB - 10/29/2021 at 03:25
Download
Dante No History Side A.stl
Standard Tesselated Geometry - 897.64 kB - 10/29/2021 at 03:24
Download
Dante No History Side B.stl
Standard Tesselated Geometry - 534.46 kB - 10/29/2021 at 03:24
Download
IMG_6175.mov
quicktime - 11.47 MB - 10/29/2021 at 03:23
Download
View all 18 components
  • But What Does It Actually Do?
    scubabear10/29/2021 at 03:07 0 comments
    The Magic Castle® has had a tradition of making souvenir keychains for the members that contain RFID chips inside them.  This allows us to build gags that can be specially triggered, which is a fun & magical thing for Castle guests to do.  Additionally we can have the RFID linked to information about the key's owner, like calling them by name.
    The tribute to the Lament Box from Hellraiser houses the RFID reader board, a 24-LED Adafruit Neopixel ring, and a PCB made by Michael Volchock that does the I2C to the reader, transmits it via RS485 to whatever it is controlling (in my case, Raspberry Pi 3s), and does a little animation on the Neopixel ring when the RFID is read.  I found a lament box STL on Thingiverse and added the little devil and the hell-level numbers.
    Then I printed a set on my Form2, made silicone molds from the 3D prints, and cast & painted 12 of them for the other gags at the Castle this year, although I only needed one of them for the arcade cabinet.
    Halloween 2021 RFID Keyfob
    There are two ways to activate the Sorter Cabinet.  The preferred way is swipe your little devil keyfob and place your hand on the handprint.  The "handprint" is a resin cast that looks like a hand pressed into stone.  Behind the resin handprint is some copper foil tape to act as antenna for the Adafruit touch sensor board.  When the handprint is touched, the Sorter is triggered and the fun begins.  The Sorter will play a musical selection for 20 seconds while it assesses your sins and determines your eternity.  Then it will say your name, the level of hell you deserve, and print a paper receipt with the level, Jeremy's illustration and a quote from Dante's Inferno.  If you don't have a keyfob, just placing your hand there will trigger it, but it will call you a "lost soul" rather than call you by name.
    It amuses me greatly that the voice that announces your eternal fate sounds just like Alexa.
  • The Artwork is Everything
    scubabear10/28/2021 at 08:57 0 comments
    I wanted Jeremy Owen to create an illustration for each of the 9 Levels of Hell in Dante's Inferno.  Jeremy was hip to the idea and got started right away.  I was really in love with the illustrations of Gustave Doré (I knew his work from an illustrated version of "The Rime of the Ancient Mariner").  Doré also did an illustrated version of Dante's Inferno... I considered using this (public domain FTW!) but the formats of the illustrations varied so much it would be a project in itself just to try to reformat to something that would work for my tester thing.  I also really liked the work of Edward GoreyGris Grimley and of course Heironymous Bosch, but I also really wanted Jeremy's own style and to see what he'd come up with.  I was not disappointed!
        "Limbo"
        "Fraud"
        "Treachery"
  • Figuring Out What the Hell to Do
    scubabear10/28/2021 at 08:34 0 comments
View all 3 project logs
  • 1
    Making the Central Display
    Hire Jeremy to do the artwork for you.  Then set up the illustrations in Illustrator for printing & routing.
    Print the graphics in reverse using a Mimaki onto 1/8" clear polycarbonate:
    After printing the transparent colors, print a white backer.  This will make the colors pop and add some diffusion for the LEDs.
  • 2
    Make the Backers to direct & confine the LED Backlights
    Stick LED tape down onto 3/8" MDF to create the light source/backer. Use foil tape to make buses; you won't want to use actual wire because that thickness could cause light leak problems later on.
    Use 30ga wrap wire to interconnect.  Note that I've also used Kynar tape where connections had to be layered.
    Route out 4 pieces of 3mm Sintra.  When stacked these will create enough distance between the LEDs and the graphic to allow the LED light to diffuse and not look too sourcy.
  • 3
    Flip It Over & Wire It Up!
    Use copper foil tape on the backside of the solid MDF backer where the LEDs are attached on the opposite side. I love this construction technique, it was fun making this!  Lay the foil down to create buses and pads, almost like making a giant PCB.  Solder the MOSFETs to the copper foil tape, using the long piece as a common ground bus on the MOSFET source & individual pads for the MOSFET drains.  Prior to putting the MOSFETs down I bent the gate pin upward so as to not touch the ground bus.
View all 6 instructions
Big Alien Robot wrote 11/04/2021 at 13:53 point
Absolutely magnificent! Extra Oingo Boingo Bonus Points!!!
