In this project, you’re going to make a Dash Button OR Wi-Fi Button using an ESP8266. Dash button is mostly used to trigger an event like a home automation event, service event, etc. Dash Button is just like a remote control that you can put into your pocket or place anywhere that when pressed sends out an email. It can also be called a DIY Amazon Dash Button.
JLCPCB is the foremost PCB prototype & manufacturing company in china, providing us with the best service we have ever experienced regarding (Quality, Price Service & Time).
Hardware Required
Circuit Diagram
Code
 * ESP8266 Wi-Fi Button
 * Project Details at https://Circuits-DIY.com
#include <ESP8266WiFi.h>
// Replace with your SSID and Password
const char* ssid     = "Circuits DIY";
const char* password = "03433212601";
// Replace with your unique IFTTT URL resource
const char* resource = "https://maker.ifttt.com/trigger/Button_Pressed/with/key/gdPQ76f331xwJUyL-25zLJHgjFM1U0u2YNT3fGu_s20";
// How your resource variable should look like, but with your own API KEY (that API KEY below is just an example):
//const char* resource = "/trigger/button_pressed/with/key/nAZjOphL3d-ZO4N3k64-1A7gTlNSrxMJdmqy";
// Maker Webhooks IFTTT
const char* server = "maker.ifttt.com";
void setup() {
  Serial.begin(115200);
  initWifi();
  makeIFTTTRequest();
  // Deep sleep mode until RESET pin is connected to a LOW signal (pushbutton is pressed)
  ESP.deepSleep(0);
void loop() {
  // sleeping so wont get here
// Establish a Wi-Fi connection with your router
void initWifi() {
  Serial.print("Connecting to: ");
  Serial.print(ssid);
  WiFi.begin(ssid, password);
  int timeout = 10 * 4; // 10 seconds
  while(WiFi.status() != WL_CONNECTED  && (timeout-- > 0)) {
    delay(250);
    Serial.print(".");
  Serial.println("");
  if(WiFi.status() != WL_CONNECTED) {
     Serial.println("Failed to connect, going back to sleep");
  Serial.print("WiFi connected in: ");
  Serial.print(millis());
  Serial.print(", IP address: ");
  Serial.println(WiFi.localIP());
// Make an HTTP request to the IFTTT web service
void makeIFTTTRequest() {
  Serial.print("Connecting to ");
  Serial.print(server);
  WiFiClient client;
  int retries = 5;
  while(!!!client.connect(server, 80) && (retries-- > 0)) {
    Serial.print(".");
  Serial.println();
  if(!!!client.connected()) {
  Serial.print("Request resource: ");
  Serial.println(resource);
  client.print(String("GET ") + resource +
                  " HTTP/1.1\r\n" +
                  "Host: " + server + "\r\n" +
                  "Connection: close\r\n\r\n");
  int timeout = 5 * 10; // 5 seconds
  while(!!!client.available() && (timeout-- > 0)){
    delay(100);
  if(!!!client.available()) {
     Serial.println("No response, going back to sleep");
  while(client.available()){
    Serial.write(client.read());
  Serial.println("\nclosing connection");
  client.stop();
