Lora AC Dimmer chopper circuit is based on Triac BT139, and zero-cross checking circuit, it detects the zero-cross points and then the Triac controlled to chop the AC. Besides, to avoid the problem of AC can not be totally shunted off with Triac, a relay is implemented to make the AC totally On/Off. On-board AC/DC module implemented, so no external power supply needed, suitable for field applications.
Chopper 0%
Chopper 17%
Chopper 49%
Chopper 80%
Makerfabs
Silícios Lab
engineerkid1
kamalkedin123
