Ameba Arduino: Upload PM2.5 Data to LASS System
The LASS stands for “Location Aware Sensor System”. It is an open project and was started only for the interest of public welfare.
0 followers
The LASS stands for “Location Aware Sensor System”. It is an open project and was started only for the interest of public welfare. Find detailed introduction here. Practically, LASS is based on MQTT protocol to collect all kinds of uploaded data, and for those who need these data can subscribe top as well. Find more LASS information at their official hackpad. In this example, we use applications mentioned at our website, including: MQTT: a MQTT-Broker to connect to LASS. The Client is “FT1_0XXXX”, the XXXX are the four last digits of Ameba’s Wi-Fi MAC, and the outTopic is “LASS/Test/Pm25Ameba/clientID“, where clientID is the actual Ameba’s MQTT client ID. NTP: uploaded data must have time notation PM2.5: uploaded data includes PM2.5 information
For more information:
  • 1 × RTL8722DM MINI
  • 1
    Code Edition
    Open the example. “File” -> “Examples” -> “AmebaMQTTClient” -> “lass_basic”
    10-1
    This example requires internet connection, so make sure you fill in SSID and PASS into AP information that you wish to connect.
    Also, LASS requires GPS information. There is no GPS sensor included in this example, so you must manually provide GPS information. Use Google Map to find the coordinates you plan to place your Ameba. You can see in this example that the latitude is 24.7814033, and the longitude is 120.9933676
    10-2
    Fill in GPS info at gps_lat and gps_lon.
    10-3
  • 2
    Hardware Connection
    RTL8722DM / RTL8722CSM:
    10-4
    RTL8722DM MINI:
    10-4
  • 3
    Upload and Execution
    Open Serial Monitor to see the uploaded data, including client id, topic, and current PM2.5 status.
    10-5
    We can also use MQTTlens to verify if the data is properly uploaded.
    Enter “gpssensor.ddns.net” as the MQTT-Broker server and “LASS/Test/PM25/live” as the subscribe topic to receive data.
    The time uses UTC format, and the PM2.5 data stores in s-d0. In the figure, s_d0 = 9 represents that the PM2.5 is 9, meaning that the entire publish/ subscribe process is working successfully.
    10-6
View all 3 instructions
