MC-10 A/V mod Board
Use composite Video instead of RF in your Tandy Micro Color Computer
Audio/Video board that replaces RF modulator on Tandy MC-10 micro color computer on a DIY friendly single sided PCB
The Video circuit is based on the MC6847 datasheet. The transistors have been replaced by European equivalents and two trimpots were added to allow the adjustment of both DC and AC output.
The audio circuit is a voltage divider with a damping capacitance to form a low pass filter with cut frequency around 5.88 kHz.
The output uses a P2 stereo Jack which allows the use of ready made P2 Stereo to RCA cable. Video sits on the Tip and audio on the Ring of the P2 connector
The PCB was tried out sometimes using a paper printed replica until the size of the board match the size of the PCB inside the RF modulator while keeping the two header connectors at the same position.
The PCB was layed out single sided and it was designed to be DIY friendly.
Some of the components admit some freedom of choice:
  • The trimpots R11, R12 and R13
  • The choke inductor L1
  • The trimmer C3
Below there is a reference of part numbers and sizes for such components.
And here is the full schematic
  • 1 × MC1372 Semiconductors and Integrated Circuits / Misc. Semiconductors and Integrated Circuits
  • 1 × BC560 Discrete Semiconductors / Transistors, MOSFETs, FETs, IGBTs
  • 1 × BC338 Discrete Semiconductors / Transistors, MOSFETs, FETs, IGBTs
  • 1 × 1N4148 Discrete Semiconductors / Diodes and Rectifiers
  • 1 × 75 Ohms Resistor THT 1/4 Watt
View all 26 components
  • New PCB installed and adjusted
    danjovic09/03/2022 at 17:15 2 comments
    Finally found some spare time to install and adjust the new board.
    First thing I have noticed is that the height of the pin header spacers were not  enough to provide clearance for the P2 jack.
    To workaround that I have removed the spacers from other pin headers and stacked them on the top of the existing ones
    The remaining length of the pins was enough to pass through the board and solder them in place
    After that there was clearance enough to insert the P2 plug.
    Nevertheless I should design another board using the original P2 jack, and enhance the centering of the output jack.
    Adjustments
    The adjustments went normal, as with the other board. I have used a program to produce all possible colors on the screen
    10 CLS 5
    20 FOR F = 0 TO 255
    30 PRINT  CHR$(F);
    40 NEXT F
    • DUTY adjustment adjusts the amplitude of the color component in the signal, but the effect of the adjustment is marginal, at least on my LCD TV.
    • AC amplitude should be adjusted to get close to 1Vpp with the video output loaded (connected to TV )
    • DC amplitude should be adjusted to bring the BIAS DC level of the video signal the most close to zero. It is not possible to get the bottom of the pedestal at 0 Volts (let alone the black level). Nevertheless adjust the DC trimpot to the point where the sync tip starts to shrink
    Results
    The resulting image is nice, just like with the previous version of the board (which is just like expected as the schematics are the same.
  • New PCB assembled
    danjovic08/11/2022 at 01:59 1 comment
    All components fits nicely.
    Checking the alignment of the mounting pins with the RF modulator can. It looks good
    Next opportunity I will assemble the board on the MC-10 and perform the adjustment.
  • Brand new PCB
    danjovic08/01/2022 at 15:11 0 comments
    I have just received the new PCB.
  • Alternative Board
    danjovic12/10/2021 at 02:18 0 comments
    Working on a study for an alternative board, using  a slightly larger PCB with a 1x2 pin headers at the  middle of each edge of the board matching with the holes for the modulator shield.
    The output connector should be changed to a PJ307 with a lower profile to compensate the extra height of the headers (compared to the previous version of the board)
    Board Layout.  It was necessary to move some components and it looks like the lower right corner may need some relief to not interfere withe the power input jack.
    PJ307
    Pin Header 1x2
  • Wrapping up
    danjovic11/28/2021 at 13:16 0 comments
    I have added a capacitor to the prototype. I used a 100uF / 16V part because of its diameter (the 47uF part used in debugging was too thick and I ran out of 10uF on my parts bin). The negative terminal was inserted on a hole made with a 0.8 drill bit right above the ground plane but there was no room for the hole of the positive terminal, that ended being soldered on the transistor socket.
    The most recent version of the PCB provides the holes for the bypass capacitor (C7).
    Now I was able to adjust the video signal to an acceptable quality. There is no instructions for this adjustments available on the MC1372 nor on the MC6847 datasheet.
    Then I have used the DC offset and AC gain potentiometers to have the video with similar proportions as the NTSC standard. I think I should dig a little more on that, but so far I have the colors with the hues expected (to may eyes).
    I removed the transistor sockets and soldered the prototype board on its place.
    After closing the case the P2 socket was perfectly aligned with the plastic case
  • Experimenting with the Bypass Capacitor
    danjovic11/22/2021 at 16:09 0 comments
    I have experimented with some values for the bypass capacitors. Anything above 10uF should work fine. The blue trace was taken at the capacitor of the PNP transistor (the circuit's VCC) and the yellow trace is the video output, acquired on an empty line to be able to see the ripple along the whole line.
    Any value above 10uF should do. Below is the overlap of voltage waveform using a 47uf (in Red) over the 10uF (in blue). Not much difference.
    And the image below shows the shadow caused by the ripple of the Vcc voltage.
  • PCB Updated
    danjovic11/22/2021 at 04:40 0 comments
    I have just updated the PCB:
    • Added the 47uF bypass capacitor on Vcc
    • Added two testpoints for the output video and audio signals
    • Added a third footprint option for the trimpot (3296W)
    • Added extra pad for the crystal load capacitor C4 to compensate differences in footprint
    • Added extra pads for the Inductor to compensate differences in footprint
    • Aligned the hole for the GND braid with the hole of the modulator shield on the motherboard
  • Tests, adjustments
    danjovic11/21/2021 at 20:31 0 comments
    The MC-10 PCB received a piece of auto-adhesive poly-carbonate from a leftover sign to isolate the AV/Board from the motherboard.
    Two rows of SIL headers have been soldered to the A/V board
    And the board was mounted on the MC-10.
    The first run looked ok!
    But running a program to test the characters showed that the colors did not looked as expected,
    At least the memory now shows the expected amount of (3102 bytes) due to the OR logic provided by the extra 74LS32.
    After some experiments with the trimpots, I still didn't have the right colours showing up (btw the screen can be cleaned by CLS[1-8] command.
    I checked the waveform of the video signal and it presented some distortions.
    Suspecting of the transistors I have used, I took the  board out and istalled some sil sockets to allow ease replacement of the transistors.
    I have experimented with a bunch of transistors from my parts bin, both NPN and PNP from series BC2xx, BC3xx and BC5xx and noticed that :
    The "first" transistor (PNP) makes the most difference. At the end the PNP transistors that best performed were the BC55x series, being the BC556 the one that provided the greatest output amplitude for a same position of the potentiometers.
    The picture below shows the difference between the BC328 (in yelllow) and a BC560 (in white)
    At the end I was able to adjust the colors to an acceptable hue, but did not get rid of the distortion on the signal, easily noticed on the sync region.
    Then I measured the waveform at the output of the MC1372 (the base of the PNP transistor) and found a fluctuation on the voltage with exactly the same profile of the distortion on the waveform.
    Checking the schematics again, I have noticed that the original circuit uses solely a 22nf power supply bypass capacitor alas the schematics from the MC1372 datasheet have a 10uF capacitor.
    Then I took a random electrolytic from my parts bin, a 47uF and attached it between pins 4 and 11 and voilà! The nasty ripple disappeared.
    I will update the schematics to include the capacitor.
  • Prototype Assembled
    danjovic11/13/2021 at 01:45 0 comments
    Just finished to assemble the prototype of the A/V board.
    I was able to reuse the trimmer from the original modulator board, but it was necessary to bend the leads of the inductor and the trim-pots
    I have already updated the board layout to accommodate the alternate footprints for the trim pot, the inductor and also the trimmer. I should print the board on paper to do a tryout before uploading the sources to github
    It was not possible to have an alternate jack. I should release 2 more versions for alternate types of 3.5mm jacks.
  • Alternative footprints
    danjovic11/12/2021 at 16:05 0 comments
    The trimpots, the trimmer and the inductor  have their footprints slightly different from the my libraries, but they were the ones I could find for purchase.
    I usually wait for all components in hand before etch a prototype board but I could not afford  more time to order them again and wait for the delivery, so I will bend the terminals and proceed to the testing/adjustments.
    On the other hand I will update the PCB to accept some alternative footprints for this components, an probably add an alternative for the 3.5mm jack.
View all 11 project logs
Slaanesh wrote 12/20/2022 at 22:47 point
Nice project, any chance of a PAL version of this?
The PAL MC-10 is quite different to the NTSC version.
leaded solder wrote 12/22/2021 at 20:33 point
Excited to see how the latest (Dec) revision of this board works out. Thank you for making it!
danjovic wrote 09/03/2022 at 17:16 point
Thanks! It worked fine, with home for improvements, though. I have just posted the results.
Fedro Ponce de León wrote 11/11/2021 at 23:42 point
I have an MC=10 with a faulty RF modulator. I would be happy to test this circuit out. Wondering if there are any gerbers available to get some PCBs to implement it.
danjovic wrote 11/12/2021 at 15:38 point
The eagle files are available in the project's GitHub repository.
Fedro Ponce de León wrote 11/17/2021 at 18:03 point
Thanks.. I've downloaded them from the repository. Another doubt... are there part numbers available for the L1 inductor and 3R3 Trmpod? I have not been able to source them.
Fedro Ponce de León wrote 07/17/2022 at 20:35 point
I have been trying to get hold of appropiate L1 inductors to complete a couple of boards. However, both NEOSID and API Delevan inductors are hard to get. Wondering if any other type of inductor may work... like Color Ring Inductors such as https://www.ebay.com/itm/323918482962 or https://www.ebay.com/itm/223729462950 would be acceptable -different packaging though.
Benoit Morrissette wrote 11/10/2021 at 19:42 point
I've had both Coco II and III.  The II had both a 6847 AND a 1372 already inside the case.  I remember opening the little RF box to bypass the rf modulator  to get directly  the video output.  You will need the original schematics for that.
Steve wrote 11/10/2021 at 17:02 point
Since this is based on the 6847, is there any reason this would only work on the MC10 and not on the other COCO models?
danjovic wrote 11/12/2021 at 15:46 point
Well the schematic is derived from the MC6847 datasheet, so it should work on any computer that uses it.
