not_yet_a_name_kbd
HAND-WIRED KEYBOARD | 60% | RP2040 "PICO"
This project is an hand-wired 60% ortholinear keyboard with a rp2040 "pico" controller.
Goal : end with a rich feature keyboard. Learn Python.
Theme : kind of cyber "low-tech" punk, minimalist open air style ( stainless steel, carbon, acrylic ).
Color : TBD ( some neon one ). Switchs are "warning sign" yellow ( Gateron Cap v2 ).
Main Difficuties : deal with in-switch led plus RGB led power consumption and io.
  • 75 × Keycap Some cheap blank DSA
  • 70 × 50g switch Gateron Cap v2 - Gold [ 62g - linear - quiet ]
  • 12 × 100g switch Kbdfans Aliaz [ 100g - tactile - silent ]
  • 75 × Hotswap socket Kailh
  • 75 × 3mm led Flat top
View all 10 components
  • COMPONENTS : 60% bent case
    kbdninja01/17/2022 at 21:02 0 comments
    60% Stainless steel bent case. Ortholinear 75 keys ( 5 x 15 ).
    Dimenions ≅ 29.5 cm * 11.1 cm
    Back height ≅ 2.4 cm
    Front height ≅ 1.5 cm
    Angle ≅ 5°
View project log
dearuserhron wrote 11/03/2021 at 16:36 point
Good luck with the keyboard. Take a look here #Wrong keyboard
kbdninja wrote 11/04/2021 at 00:09 point
Thank you. I have look, I will stick with switchs and keycaps.
