Working ExplanationWorking Explanation
Introduction
electrical student, then you must have seen its applications. or you must have used it in various projects. Because apparently, DC motors are in every other application, either industrial or at an academic level. So, Learning to control the speed of the DC motor Speed is an essential thing to discuss. Different applications require different speed levels of the DC motors for their project or machine.
PCBWay commits to meeting the needs of its customers from different industries in terms of quality, delivery, cost-effectiveness, and any other demanding requests. As one of the most experienced PCB manufacturers in China. They pride themselves to be your best business partners as well as good friends in every aspect of your PCB needs.
Hardware Components
Circuit Diagram
Working Explanation
In this DC Motor Speed Control, IC 555 is working as a square pulse generator depending on the value of the potentiometer. The output pulse width or duty cycle can get changed through that potentiometer
