• Research, research, research...
    Alex Cartier07/08/2014 at 23:56 0 comments
    As with every great idea, someone had it long before you... However, that just let's you work harder to enhance those ideas and to twist and tweak them until you finally have something that is unique and outperforms everything else that's out there.  At this point in the game I am looking through hundreds of search results, finding the dos and don'ts of everything from flight sims, hand gestures, drone control, hell even a little aerodynamics.  In true O.M.A. fashion I will exhaust the endless bounds of the internet to find the best way to accomplish my goal... And then I will finally sleep again.
