Assembled prototype
A project log for FA-32 recreation
DIY alternative to the cassette interface for CASIO PV-7 and MX-10 / 101
danjovicdanjovic 11/24/2021 at 10:570 Comments
I have assembled the prototype and worked on the plastic case to fit the board.
I have also built the cables using the shoestring technique (except for the DB-9 t- DIN cable, as a didn't have a thick enough shoestring at the moment of the build).
Worth to mention that I have used dental floss to tighten the ends of the cloth string.
And here is some pictures of the adapter and cables together
