Example node
A project log for Making an old Air Purifier smart
adding the Phillips AC4014 to a Home Assistant network
antonAnton 11/20/2021 at 00:340 Comments
An example for a node red implementation:
in Home assistant I've added a dropdown under "helpers":
with that in place, I can select between "manual" which simply does only what is selected on the air purifier or on HA (on/off, fan speed), "automatic" which uses air quality measurement as a criteria for on/off and fan speed or "time" which turns the AP on and off at a specific time at a specific fan speed.
here is the node:
        "id": "0bdc4f11ed52dc5d",
        "type": "tab",
        "label": "Air Purifier 3",
        "disabled": false,
        "info": "",
        "env": []
        "id": "5e0fa840110275e8",
        "type": "api-call-service",
        "z": "0bdc4f11ed52dc5d",
        "name": "on/off",
        "server": "1bb0d825.3e7398",
        "version": 3,
        "debugenabled": false,
        "service_domain": "switch",
        "service": "toggle",
        "entityId": "switch.air_3_on_off",
        "data": "",
        "dataType": "jsonata",
        "mergecontext": "",
        "mustacheAltTags": false,
        "outputProperties": [],
        "queue": "none",
        "x": 970,
        "y": 820,
        "wires": [
                "ba87b75e6fefc6fe"
        "id": "d08272d7bfb1789e",
        "type": "inject",
        "name": "",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "10",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "",
        "payloadType": "date",
        "x": 190,
        "y": 120,
        "wires": [
                "7ce007c55044a93b"
        "id": "32d95505345eeb3c",
        "type": "switch",
        "name": "switch on: \\n <10, <=20, <=50, >=100",
        "property": "payload",
        "propertyType": "msg",
        "rules": [
                "t": "lt",
                "v": "10",
                "vt": "num"
                "t": "lte",
                "v": "20",
                "vt": "num"
                "t": "lte",
                "v": "50",
                "vt": "num"
                "t": "gte",
                "v": "100",
                "vt": "num"
        "checkall": "false",
        "repair": false,
        "outputs": 4,
        "x": 170,
        "y": 960,
        "wires": [
                "69d3c175ae98a9a6"
                "228bd948a665d7bc"
                "d630f8370ece3b7e"
                "805c6911af7286e6"
        "id": "8758ba24542abccb",
        "type": "api-current-state",
        "name": "get measurement \\n 10pm sensor",
        "version": 2,
        "outputs": 2,
        "halt_if": "0",
        "halt_if_type": "num",
        "halt_if_compare": "gte",
        "entity_id": "sensor.particulate_matter_10_0um_concentration",
        "state_type": "num",
        "blockInputOverrides": false,
                "value": "",
                "valueType": "entityState"
                "property": "data",
                "value": "",
                "valueType": "entity"
        "x": 210,
        "y": 580,
        "wires": [
                "32d95505345eeb3c"
        "id": "69d3c175ae98a9a6",
        "type": "change",
        "name": "change to 1",
        "rules": [
                "t": "set",
                "p": "payload",
                "pt": "msg",
                "to": "1",
                "tot": "num"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 390,
        "y": 900,
        "wires": [
                "6d0cd96036706e97"
        "id": "228bd948a665d7bc",
        "type": "change",
        "name": "change to 2",
        "rules": [
                "t": "set",
                "p": "payload",
                "pt": "msg",
                "to": "2",
                "tot": "num"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 390,
        "y": 940,
        "wires": [
                "6d0cd96036706e97"
        "id": "d630f8370ece3b7e",
        "type": "change",
        "name": "change to 3",
        "rules": [
                "t": "set",
                "p": "payload",
                "pt": "msg",
                "to": "3",
                "tot": "num"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 390,
        "y": 980,
        "wires": [
                "6d0cd96036706e97"
        "id": "6d0cd96036706e97",
        "type": "rbe",
        "name": "",
        "func": "rbe",
        "gap": "",
        "start": "",
        "inout": "out",
        "septopics": true,
        "x": 570,
        "y": 960,
        "wires": [
                "6f75c4d6d13132f8"
        "id": "6f75c4d6d13132f8",
        "type": "switch",
        "name": "",
        "rules": [
                "t": "eq",
                "v": "1",
                "vt": "num"
                "t": "eq",
                "v": "2",
                "vt": "num"
                "t": "eq",
                "v": "3",
                "vt": "num"
                "t": "eq",
                "v": "4",
                "vt": "num"
        "checkall": "true",
        "repair": false,
        "outputs": 4,
        "x": 670,
        "y": 840,
        "wires": [
                "93457cb56bc2ea42"
                "51960ae7dc52dc95"
                "2c3c05e44a952fd5"
                "29d971730bab8ff5"
        "id": "7e23ab4e672858d1",
        "name": "on/off",
        "version": 3,
        "data": "",
        "mergecontext": "",
        "queue": "none",
        "x": 970,
        "y": 760,
        "wires": [
                "43a9eb74610ec9d1"
        "id": "93457cb56bc2ea42",
        "name": "if off",
        "version": 2,
        "outputs": 2,
        "halt_if": "off",
        "halt_if_type": "str",
        "halt_if_compare": "is",
        "entity_id": "binary_sensor.airpurifier3",
        "state_type": "str",
                "value": "",
                "property": "data",
                "value": "",
        "x": 830,
        "y": 760,
        "wires": [
                "7e23ab4e672858d1"
        "id": "dfeaa6d4edd5423e",
        "name": "on/off",
        "version": 3,
        "data": "",
        "mergecontext": "",
        "queue": "none",
        "x": 970,
        "y": 900,
        "wires": [
                "2946f6aada43ac55"
        "id": "cc9c66af89230026",
        "name": "fan",
        "version": 3,
        "entityId": "switch.air_3_fan",
        "data": "",
        "mergecontext": "",
        "queue": "none",
        "x": 1310,
        "y": 900,
        "wires": [
                "ee962ecd5962b9b5"
        "id": "7ce007c55044a93b",
        "name": "operation mode",
        "version": 2,
        "outputs": 2,
        "halt_if": "manual",
        "halt_if_compare": "is_not",
        "entity_id": "input_select.master_bedroom_air_purifier",
                "value": "",
                "property": "data",
                "value": "",
        "x": 200,
        "y": 300,
        "wires": [
                "d4cd761f8f6de816"
        "id": "805c6911af7286e6",
        "type": "change",
        "name": "change to 4",
        "rules": [
                "t": "set",
                "p": "payload",
                "pt": "msg",
                "to": "4",
                "tot": "num"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 390,
        "y": 1020,
        "wires": [
                "6d0cd96036706e97"
        "id": "7e3cfd2c33c74f5c",
        "name": "on/off",
        "version": 3,
        "data": "",
        "mergecontext": "",
        "queue": "none",
        "x": 970,
        "y": 1120,
        "wires": [
                "327d0dc8de88dfd4"
        "id": "faa5957d77558406",
        "name": "fan",
        "version": 3,
        "data": "",
        "mergecontext": "",
        "queue": "none",
        "x": 1270,
        "y": 1120,
        "wires": [
                "509d7e93e7c0b6a4"
        "id": "ffd89851cdcfb19e",
        "name": "fan",
        "version": 3,
        "data": "",
        "mergecontext": "",
        "queue": "none",
        "x": 1550,
        "y": 1120,
        "wires": [
                "f88e5d8d8eeed8d7"
        "id": "509d7e93e7c0b6a4",
        "type": "delay",
        "name": "",
        "pauseType": "delay",
        "timeout": "1",
        "timeoutUnits": "seconds",
        "rate": "1",
        "nbRateUnits": "1",
        "rateUnits": "second",
        "randomFirst": "1",
        "randomLast": "5",
        "randomUnits": "seconds",
        "drop": false,
        "outputs": 1,
        "x": 1400,
        "y": 1120,
        "wires": [
                "ffd89851cdcfb19e"
        "id": "2946f6aada43ac55",
        "type": "delay",
        "name": "",
        "timeout": "1",
        "rate": "1",
        "nbRateUnits": "1",
        "randomFirst": "1",
        "randomLast": "5",
        "drop": false,
        "outputs": 1,
        "x": 1140,
        "y": 900,
        "wires": [
                "cc9c66af89230026"
        "id": "327d0dc8de88dfd4",
        "type": "delay",
        "name": "",
        "timeout": "1",
        "rate": "1",
        "nbRateUnits": "1",
        "randomFirst": "1",
        "randomLast": "5",
        "drop": false,
        "outputs": 1,
        "x": 1120,
        "y": 1120,
        "wires": [
                "faa5957d77558406"
        "id": "43a9eb74610ec9d1",
        "type": "change",
        "name": "set fan speed 0",
        "rules": [
                "t": "set",
                "p": "payload",
                "pt": "msg",
                "to": "0",
                "tot": "num"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 1160,
        "y": 720,
        "wires": [
                "325bf80ad4b65dda",
                "2e255df180ef5c58"
        "id": "ba87b75e6fefc6fe",
        "type": "change",
        "name": "set fan speed 1",
        "rules": [
                "t": "set",
                "p": "payload",
                "pt": "msg",
                "to": "1",
                "tot": "num"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 1160,
        "y": 820,
        "wires": [
                "325bf80ad4b65dda",
                "2e255df180ef5c58"
        "id": "ee962ecd5962b9b5",
        "type": "change",
        "name": "set fan speed 2",
        "rules": [
                "t": "set",
                "p": "payload",
                "pt": "msg",
                "to": "2",
                "tot": "num"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 1500,
        "y": 900,
        "wires": [
                "325bf80ad4b65dda",
                "2e255df180ef5c58"
        "id": "f88e5d8d8eeed8d7",
        "type": "change",
        "name": "set fan speed",
        "rules": [
                "t": "set",
                "p": "payload",
                "pt": "msg",
                "to": "3",
                "tot": "num"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 1740,
        "y": 1120,
        "wires": [
                "325bf80ad4b65dda",
                "2e255df180ef5c58"
        "id": "40680816722e3848",
        "name": "fan <2",
        "version": 2,
        "outputs": 2,
        "halt_if": "2",
        "halt_if_compare": "lt",
        "entity_id": "LR/Airpuri3/Fanspeed",
                "value": "",
                "property": "data",
                "value": "",
        "x": 970,
        "y": 1000,
        "wires": [
                "2946f6aada43ac55"
                "53c8d37d0f904999"
        "id": "53c8d37d0f904999",
        "type": "switch",
        "name": ">2",
        "rules": [
                "t": "gt",
                "v": "2",
                "vt": "num"
        "checkall": "true",
        "repair": false,
        "outputs": 1,
        "x": 1140,
        "y": 1040,
        "wires": [
                "b1f30937037c77cd"
        "id": "b1f30937037c77cd",
        "type": "delay",
        "name": "",
        "timeout": "1",
        "rate": "1",
        "nbRateUnits": "1",
        "randomFirst": "1",
        "randomLast": "5",
        "drop": false,
        "outputs": 1,
        "x": 1320,
        "y": 1040,
        "wires": [
