Bracelet Mounting
A project log for ComputeDeck-B3
Raspberry Pi Zero W 2 Arm mounted Cyberdeck with a Chorded Keyboard
atltvheadatltvhead 08/22/2022 at 12:210 Comments
The design of the main interface between the Cyberdeck and the arm is underway!
The interface itself will be foam wrapped in fabric and glued into each half of the bracelet. As the bracelet closes the foam comforms around the arm. There will be a total of two of these brackets with supporting structure between them and some mounting for the electronics.
The cliping mechanism is based off a pelican snap. I'll share more details with its finalized after some printing.
