Build Started!
A project log for ComputeDeck-B3
Raspberry Pi Zero W 2 Arm mounted Cyberdeck with a Chorded Keyboard
atltvheadatltvhead 09/10/2022 at 19:150 Comments
The build has officially begun! I am missing some M3 screws; however, I have the first ring on! I'll start cutting out the foam soon.
 If you noticed that the battery pack print is different, I am using Protopasta nebula. there was a small tweak to the cad of this part and that filament is what I had loaded.
