As a test for the new 3D printer :) a robot project was set up! The robot should have a decent size, but still be easy to manufacture and assemble. Main design decisions were:
- Small stepper motors
- Modular set up for the gear boxes, the robot uses three identical drive units
- Gear box with wolfrom gear stage 1:76
- Ball bearings in all joints
The robot has been set up in SolidWorks, the .stl and .step files will be available soon.
The gearbox has its own project with Step and STL files:
https://hackaday.io/project/187926-robot-gearbox
Currently assembling the basic robot, test, improvements, vacuum gripper, 4th rotational axis, referencing switches etc are still missing...
Hi, the user guide in English is still in German language when I try to download it from website. Can you give me the link to download the version in English. Thanks
Hi Theodore, sorry for the late reply! I uploaded the CAD files as step and stl, I hope you can use them. There are not all parts modeled, I will further instructions.
I used electronics from PoLabs, the PoKeys57E controller and PoStep25 stepper motor controller.
As programming software I use the RDC from RobotDimension. The maker version is free.
Hi, I wanted to know , is it possible to share a video of the robot arm moving in action ? I would appreciate it.
