JAVATC Calculations for this Mini SGTC
A project log for Mini Tabletop Tesla Coil Powered by an Arc Lighter
Rechargeable Portable Spark Gap Tesla Coil for Science Demonstrations
tom-meehanTom Meehan 12/06/2021 at 02:320 Comments
This is a copy of my inputs to JAVATC and the values it returned:  Mini Tabletop SGTC (inspired by Plasma Channel)
Calculations made using: J A V A T C version 13.1 - CONSOLIDATED OUTPUT
        Units = Inches
        Ambient Temp = 68°F
Surrounding Inputs:
Secondary Coil Inputs:
Primary Coil Inputs:
Helical primary coil form (not a pancake coil)
Top Load Inputs:
Toroid :
Secondary Outputs:
Primary Outputs:
I'm putting together a few diagrams to make values like major and minor diameter of toroid, as well as the various heights mentioned.  There may be some missing dimensions (like insulation on wire in primary coil)  but I will add these.
