JAVATC Calculations for this Mini SGTC
12/06/2021 at 02:32 • 0 commentsThis is a copy of my inputs to JAVATC and the values it returned: Mini Tabletop SGTC (inspired by Plasma Channel)
Calculations made using: J A V A T C version 13.1 - CONSOLIDATED OUTPUT
Units = Inches
Ambient Temp = 68°F
Surrounding Inputs:
- 100 = Ground Plane Radius
- 0 = Wall Radius
- 0 = Ceiling Height
Secondary Coil Inputs:
- 0.83 = Radius of Secondary
- 3.5 = Height 1 (start height of winding)
- 8.5 = Height 2 (end height of winding)
- 570 = Turns
- 32 = Wire AWG
Primary Coil Inputs:
Helical primary coil form (not a pancake coil)
- 1.5 = Radius
- 2.83 = Height 1
- 3.368 = Height 2
- 11.0339 = Turns
- 0.0253 = Wire Diameter
- 0.0013 = Primary Cap (uF)
Top Load Inputs:
Toroid :
- minor diameter = 1"
- major diameter = 4"
- height = 9" (above ground plane)
Secondary Outputs:
- 1132.46 kHz = Secondary Resonant Frequency
- 90 deg° = Angle of Secondary
- 5 inch = Length of Winding
- 114 inch = Turns Per Unit
- 0.00082 inch = Space Between Turns (edge to edge)
- 247.7 ft = Length of Wire
- 3.01:1 = H/D Aspect Ratio
- 40.3133 Ohms = DC Resistance
- 27605 Ohms = Reactance at Resonance
- 0.05 lbs = Weight of Wire
- 3.88 mH = Les-Effective Series Inductance
- 4.028 mH = Lee-Equivalent Energy Inductance
- 3.912 mH = Ldc-Low Frequency Inductance
- 5.091 pF = Ces-Effective Shunt Capacitance
- 4.903 pF = Cee-Equivalent Energy Capacitance
- 8.236 pF = Cdc-Low Frequency Capacitance
- 2.73 mils = Skin Depth
- 3.764 pF = Topload Effective Capacitance
- 134.7194 Ohms = Effective AC Resistance
- 205 = Q
Primary Outputs:
- 1132.45 kHz = Primary Resonant Frequency
- 0 % = Percent Detuned
- 90 deg° = Angle of Primary
- 8.67 ft = Length of Wire
- 140.4 mOhms = DC Resistance
- 0.023 inch = Average spacing between turns (edge to edge)
- 0.666 inch = Proximity between coils
- 0 inch = Recommended minimum proximity between coils
- 15.193 µH = Ldc-Low Frequency Inductance
- 0.0013 µF = Cap size needed with Primary L (reference)
- 0 µH = Lead Length Inductance
- 29.604 µH = Lm-Mutual Inductance
- 0.121 k = Coupling Coefficient
- 0.122 k = Recommended Coupling Coefficient
- 8.26 = Number of half cycles for energy transfer at K
- 3.62 µs = Time for total energy transfer (ideal quench time)
I'm putting together a few diagrams to make values like major and minor diameter of toroid, as well as the various heights mentioned. There may be some missing dimensions (like insulation on wire in primary coil) but I will add these.
Parts for my Arc Light Powered Tabletop Tesla Coil Design
11/22/2021 at 05:52 • 0 commentsMy parts and design for Arc Lighter Powered Tabletop Tesla Coil:
- Arc Lighter
- 32 Gauge Magnet
wire (Remington, cat.#32SNSP.25 – Solderable Polyurethane w/
Polyamide Overcoat, Diameter 0.0087”, bare wire thickness 0.00795”
so spacing between windings ideally close to 0.00075”)
- winding height for 570 turns equals 4.96”
- Primary Wire
(Gauge and diameter of insulated
wire)
- multicore xx guage wire with 0.x” insulation
- Capacitors –
39000pF, 3kVDC, Polypropylene (Panasonic ECW-HC3F392J)
- 3 in series 1.3nF 9KV capacitor bank
- Diodes for Full Bridge Rectifier 2CL2FL 15KV 100mA 100nS High Voltage Diode ( https://www.amazon.com/gp/product/B07MVX689B/ref=ppx_yo_dt_b_asin_title_o08_s00?ie=UTF8&psc=1 )
- 3mm expanded
PVC sheet
- 3 x 5"x5" squares
- 4 x 1/4" hex machine
screws 3" length
- 12 x 1/4" machine nuts
- 4 x 3/8" long nylon spacers with 1/4" I.D. hole
- Aluminum foil tape (for ground plane and to cover top-load)
- Momentary button (SPST)
- Primary coil – form, windings, height, etc. (3D printable parts with link in parts tab)
- Secondary coil - form, 1.5” PVC (xx” OD) by xx” Height, 570 windings, etc.
- Ground Plane (aluminum foil on bottom of lowest expanded PVC base/support)
- Top-Load (3D
printed toroid covered in aluminum tape)
- I tried many
different dimensions of spherical, torroidal and disc shaped
top-loads
- I prefer the look of torroidal top-loads but other shapes with similar capacitance should also work.
- I should note that I did not take into account the thickness of the aluminum tape in the final dimensions of the top-load and this likely effects the reasonant frequency of the secondary coil!
- Wiring for connecting parts (22 AWG single core wiring)
- I tried many
top-loads
Plasma Channel's List of Parts
11/22/2021 at 05:49 • 0 commentsPlasma Channel’s parts and design for Arc Lighter Powered Tabletop Tesla Coil:
- Arc Lighter (can use other ones too): https://amzn.to/31yC7Vy
- Secondary Coil
Wire - 32 gauge magnet wire: https://amzn.to/3892VhP
BNTECHGO 32 AWG Magnet Wire - Enameled Magnet Winding Wire - 4 oz -
0.0078" Diameter
- This 32AWG enameled magnet wire description states that it is 0.0078” diameter while un-insulated 32 AWG magnet wire is 0.00795” (enamel insulation would make it even thicker)
0.0078" Diameter
- Primary Coil
Wire: https://amzn.to/376JpRQ
Woods 0453 Bell Wire, 24/2, 50-Feet
- AWG 24
- no information on thickness of insulation
- Capacitors:
https://www.mouser.com/ProductDetail/...
- Diode : https://amzn.to/3cnsLQV
- Acrylic discs: https://amzn.to/2S7xFKj
- Nylon spacers: https://amzn.to/374fBoV
- Aluminum foil tape (counterpoise/for ground plane): https://amzn.to/2SqoL9T
- Primary Coil
(diameter, height of start of coil)
- # Turns = 8.5
- no diameter for coil (or the distance between the primary and secondary)
- no height for start of winding
- no insulation thickness (so no spacing between turns)
- Secondary
Coil (1.25”
I.D. equal to 1.66” O.D.,
height of start of coil, total winding height and number
of windings)
- 1.66”
O.D.
x about 4”
height (as per video
description)
- 570 turns of the above 32 AWG enameled magnet wire (by calculation this equals 4.53” winding height – a half inch past the 4” length recommended coil form)
- no height for placement of top-load
- 1.66”
O.D.
x about 4”
description)
- Top-Load
- no dimensions given
- no information on capacitance
- nothing on distance from top of secondary windings
- Ground Plane (aluminum foil on bottom of lowest acrylic base/support)
What I used from Plasma Channel’s design in my Final design
- capacitor bank
- basic secondary coil dimensions (same form, AWG magnet wire, # of windings)
- HV diodes (but used a full bridge configuration)
For a more classic Tesla Coil look I redesigned the coil with a toroid for the top-load.
Details, build instructions and links to 3D Printed parts, etc. coming very soon!
Inspiration from Plasma Channel
11/20/2021 at 22:13 • 0 commentsI really love the high voltage projects Jay shows on Plasma Channel (https://www.youtube.com/c/PlasmaChannel ). While it is sometimes difficult to replicate some of his designs they still provide excellent ideas and inspiration.
Since I am frequently inspired by the content he produces I always keep my eye out for new projects he posts and that is how I came across his build of an arc lighter powered spark gap Tesla Coil.
In attempting to replicate his build of an arc lighter powered spark gap Tesla Coil I ended up encountering a few Issues – the main one being that calculations based on his design didn’t seem to work out right. In addition, missing information made it even more difficult to replicate:
- top-load (what was used was some sort of drawer pull - no actual dimensions given).
- no specifics on the distance from the top-load to the secondary coil windings
- no estimated capacitance of top-load
- no information on coupling between the primary and secondary coils or even just the distance between the 2 coil forms
I did attempt to work around these issues since he did provide the capacitance of the primary tank circuit (capacitor bank) and the inductance of the secondary circuit (coil form dimensions including height of windings and wire gauge).
In the end I designed a new coil based on the secondary coil geometry and the primary capacitance from Plasma Channels design since I had already made these 2 elements. I also used the same High Voltage diodes that he listed except that I changed that portion of his power supply from a single diode rectifier to a full bridge rectifier (in the hopes of increasing power to the primary coil).
To check all calculation's and optimize the design I used JavaTC.
