I did a bit more programming of the security module and now it will send the detected frame and one slightly after to your email. I tested all day and found it only used about a volt of the battery pack in this mode, that works for me. Below is a email of a test of the system. The code is available on the GitHub.
*note it was found that you will need to make a "app" password after signing up for two factor with Gmail accounts specifically.
Apollo Timbers
