Firmware mishap
A project log for Roll your own Radio Telescope/camera
Take samples from an antenna, mounted to a robot that looks shockingly like a 3D printer, running slightly modified Marlin
alex-dickmanAlex Dickman 02/09/2015 at 01:591 Comment
Went to fire up the machine, AND I realized it only runs code from the serial prompt, NOT from gcode text. Whoops, may need an easier way to get around the Marlin hotend temp warning/shutdown. I'll fix it asap
Alex Dickman wrote 02/09/2015 at 17:11 point
Actually, it was the serial flush "ok" that I was trying to get rid of that caused the hangups, NOW I'm back to the temperature error lockup
