led sign.schEagle Schematic Filesch - 638.08 kB - 11/22/2021 at 16:00 |
led sign.brdEagle Board Filebrd - 102.13 kB - 11/22/2021 at 16:00 |
led sign_2021-11-22.zipPCB GerbersZip Archive - 202.13 kB - 11/22/2021 at 16:00 |
Pedestrian_Light.inoArduino sketch for Attiny85. Flashes red 10 times and holds for 10 seconds then holds white 10 seconds, then repeats. Easy enough to change to work on an Atmega328p or esp8266.ino - 512.00 bytes - 11/22/2021 at 15:55 |
Rear Case.STLPrint in yellowStandard Tesselated Geometry - 166.29 kB - 11/22/2021 at 15:49 |
Shadow Mask.STLPrint bottom in white and top in black (layer change when it first starts printing the logo layer)Standard Tesselated Geometry - 92.86 kB - 11/22/2021 at 15:49 |
Grill.STLPrint in black, I suggest scaling it up a percent or two to make a snug fit with the rear case, otherwise it will need to be glued in or have electrical tape applied to edges to fit the rear case without falling outStandard Tesselated Geometry - 367.07 kB - 11/22/2021 at 15:49 |
Light Box.STLPrint in blackStandard Tesselated Geometry - 18.25 kB - 11/22/2021 at 15:49 |
