Hackaday.io Hackaday.io
Sign up Log in
Sixi 3 robot arm actuator
stepper motor + harmonic gearbox + moldable parts
dan-royerDan Royer
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
10 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 2
    • View all
  • Instructions 0
  • Discussion 0
View Gallery
438
0
10
8
Team (1)
  • dan-royerDan Royer
Join this project's team
  • Robot Overlord control app
  • Buy the DIY kit
ongoing project
sixi ROBOT robot arm
This project was created on 11/24/2021 and last updated 4 years ago.
Description
The Sixi 2 robot arm had 1300 parts in 250 types. The Sixi 3 has 250 parts in 25 types. using a single actuator many times brings down the cost to make, repair, replace, and refactor. The software works, the design is ready for injection molding, all I really need is enough demos to show its practical applications. There is a PCB in each unit that provides always-on absolute position sensing and CANbus communication. This makes maintenance and assembly easier than ever before.
Project Logs
Collapse
  • Daisy Driver 2 preview
    Dan Royer • 01/04/2023 at 21:03 • 0 comments
    Now my challenge is to design and test the protocol that will run over CANbus.
    Also to mount the rotating disc to the harmonic drive so that I get the feedback I want.
    Join me!  Together we'll make self-assembling robot arms.
  • Jogging and programming example
    Dan Royer • 11/24/2021 at 18:21 • 0 comments
    and since then I've fully colorized the robots in the app so it's way better looking.
View all 2 project logs
Log In/Sign up to comment
Sign up with Github
Sign up with X
OR
A robot that utilizes compression springs and BLDCs to navigate various pipe structures.
Project Owner Contributor
Pi Fly 7
jfriesjfries
The 2016 Hackaday Prize
Yet Another Robot aRM - where I develop a low-cost compliant robot arm with a 1meter reach, 1KG payload.
YARRM - 7-DOF Low-Cost Robot Arm
jonathan-lussierJonathan Lussier
3D Printed Quadrupedal Robot
TOPS
aaed-musaAaed Musa
My attempt at making a fun humanoid-like robot.
Almost humanoid robot
tanguyTanguy
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Sixi 3 robot arm actuator", please tell us the reason.
Send message
Remove Member
