RunCPM (https://github.com/MockbaTheBorg/RunCPM) is an application which allows you to execute old CP/M 8 bits programs on Windows, Mac OS X, Linux, FreeBSD, MS-DOS, Arduino DUE and the Teensy. It can be built both on 32 and 64 bits host environments and should be easily portable to other platforms. RunCPM is fully written in C and in a modular way, so porting to other platforms should be only a matter of writing an abstraction layer file for it. No modification of the main code modules should be necessary.
If you miss using powerful programs like Wordstar, dBaseII, mBasic and others, then RunCPM is for you. It is very stable and fun to use. RunCPM emulates CP/M 2.2 from Digital Research as close as possible.
RunCPM was written to serve as a test environment when I was restoring the only copy of Z80 MicroMumps v4.06 which exists online (https://github.com/MockbaTheBorg/MicroMumps). Making changes, recompiling MicroMumps and loading it onto a regular CP/M emulator via a disk image every time I moved a bit forward on the restoration was becoming too time consuming. So I decided to write something that would allow me to run the executable right away after making any modifications.
RunCPM builds on Visual Studio 2013 or later. Posix builds use GCC/LLVM. It can also be built on the Arduino IDE and even on DJGPP for DOS. It can be built also on Cygwin (posix) and Mingw. Makefiles are provided with the distribution.
Marcelo Dantas
Just4Fun
doctek
Bernhard "HotKey" Slawik
Paul Stoffregen
10 FOR I = 0 TO 255
20 PRINT I;CHR$(I)
30 NEXT I
Will give you a list of all the characters available in MBASIC
32 - 126 and repeating again 160 - 254
There is room here using a custom font to have Programmable Character Graphics.
Giving you an emulated development environment inside on Laptop/Computer where target machine only needs to see the final code. e.g. Microbee, Sinclair Spectrum, Commodore 128, etc.
PETSCII could also be achieved using 2 characters at a time creating a 16x16 character..
Using MacOS I can specify the font in terminal and then Launch RunCPM, I can get basic to display WebDings.
