Introduction
A Fire alarm is a simple electronic circuit that determines the presence of any hazardous fire in its vicinity & triggers an array of preventive measures such as overhead sprinklers or an alarming array. Fire alarms are an integral safety feature in today's industry, with the government requiring mandatory fire safety SOPs & fire alarm systems for every existing industry. So, in this tutorial, we will go through a step-by-step procedure on how to make a simple fire alarm circuit using a thermistor.
PCBWay commits to meeting the needs of its customers from different industries in terms of quality, delivery, cost-effectiveness, and any other demanding requests. As one of the most experienced PCB manufacturers in China. They pride themselves to be your best business partners as well as good friends in every aspect of your PCB needs.
Hardware  Components
Circuit Diagram
Working Explanation
The working of this circuit is pretty simple. On powering up the circuit and bringing a heating element close to it, the temperature around the thermistor begins to increase. Subsequently, the resistance of the thermistor decreases Due to which the output voltage of the voltage divider increases.
