Introduction
An FM Transmitter is an electronic device that can air audio signals from a source on a selected range of frequencies. They are generally used to broadcast stationary audio from devices such as TV & computers, around a room. They are inexpensive & simple to design. So, in today's article, we will look into a step-by-step tutorial on how to make a High Range FM Transmitter circuit using some NPN transistors & a small no. of other components.
PCBWay commits to meeting the needs of its customers from different industries in terms of quality, delivery, cost-effectiveness, and any other demanding requests. As one of the most experienced PCB manufacturers in China. They pride themselves to be your best business partners as well as good friends in every aspect of your PCB needs.
Hardware Components
Circuit Diagram
Working Explanation
The working of this circuit is pretty simple, an input audio signal from a device such as a smartphone is taken through an electret mic. Here, a coupling capacitor of 0.1uF is used to block the DC component of the signal, allowing only AC to flow. This signal acts as a control signal to the base of the 2n3904 transistor (Q1).
