Custom router bit and measuring about 14 times
A project log for The workbench
A handy extremely sturdy workbench
ØysteinØystein 12/07/2016 at 08:540 Comments
So I got a call. It was the store owner of Grønvold maskin (Grønvold machineservices) . He had the custom router bit ready for me! I was so excited so I got to Grønvold maskin as fast as I could after work (they have opening times that makes it kinda difficult to shop there). I got the bit and also bought some other supplies:
And here are screws that Will fit perfectly and a very strong adhesive (cab withstand 220KG of force applied to it) to hold the to sides of the leg support together:
The screws match perfectly to where I want to use them:
I tested if I could use the to mount the table top. Seems like it is excactly what I need. on a side note I am going to attach the table tobs with the mentioned screws and doubblesided UHB (ultra high bondage) tape.
I then did practiced with the handheld router, the custom router bit and a roundoverbit:
Finally I start making the cuts for the legs. Had to measure it like 14 times to make shure everything was correct.
