Whoa! Something is actually happening!
A project log for The workbench
A handy extremely sturdy workbench
ysteinØystein 06/03/2017 at 21:070 Comments
Sooo, It´s been a while since I have worked on this project. But now I finally got time and opportunity to continue to work on this project. I tried to make the finger joints with a router and a guide. Almost half a year has past and I decided to use this newly acquired thing instead:
A Japanese handsaw. This turned out to work beautifully. So I used the guide to draw out where I should cut got to work.
After some sawing I started using a file for the small details.
I started with the fingerjoint on the sidepieces of the table. I then made the fingerjoints on the eeehm, long pieces.
and a preview withe a tableleg attached(I held the leg up with my foot hence the blurry picture):Test the front assembled Finger joint on the back side table.Suddenly:
Whoa! A frame!
ooh, the frame is assembled with legs! It still needs glue and screws but quite a lot of progress has been made. I also put the tabletop just to see how it looked:
New update will be posted soon!
