more shelf work
A project log for The workbench
A handy extremely sturdy workbench
ysteinØystein 07/09/2017 at 21:090 Comments
So today i continued with the shelf. I continued making the cable management hole in log number 2. I also start working on the steel brackets.
Here is the cable management hole tested:
I also cut the steel brackets to length.The plan is to use threaded rods and locking nuts to connect the shelf to the table.
tipptopptommelopp!
