Recently I got the new limited Ardruino Uno Mini. This is a half sized Adruino Uno. See here for more details. Due to its small size it is quite a nice baseboard for yet another tiny led matrix.
I used WS2812 compatible LEDS in a 15x9 Matrix. The PCB is designed in Kicad. This is a four Layer PCB. For the first prototypes I tried the PCB and assembly service from JLCPCB. Which worked quite well (at least the one tested PCB is working without Problems so far).
was not aware of this, cute matrix! :)
