• I just kinda slapped it together
    tyler12/09/2021 at 03:21 1 comment
    I started by using pliers to break up some safety pins (I have many problems with this name for these little abominations, by the way).
    Having done that, I bent it into the correct shape and soldered in on to the board.
    Then, I set in the next few in the shape of the battery, and marked the holes that I will use as contacts.
    And now it's time to make my solder bridges.
    Oh look, another picture.
    Ok cool, now I can-
    There I go again, solving nonexistent problems. I'll find a use for it someday, I guess.
