NE555 Dice Inversion
A modern-day reimagining of the NE555/CD4017 electronic dice
TimTim
This is for the NE555 "timer" contest
You  probably came across electronic dice do-it-yourself kits many times. The design of those has remained virtually unchanged for decades. All of them are based on exactly two ICs: A NE555 and a CD4017.
Two examples found on the internet
The CD4017 is a counter that is used to cycle through the states. The counter output is converted to the die pattern using a combination of diodes, resistors and transistors. An oscillator based on a  NE555 generates counting pulses when the die is activated.
Isn't that a bit limiting? The NE555 surely can do more than being a sidekick to the CD4017. In this project we will bring the NE555 to it's full potential and implement the entire dice using only NE555s. Along the way I also found a nice new job for the CD4017 as a two phase clock generator.
This is a companion project to the NE555 microprocessors to actually test the logic style in real hardware.
The 2021 NE555 Electronic DICE
  • And one more thing II
    Tim01/08/2022 at 11:48 7 comments
    Yann pointed out in a comment that a Johnson counter may be a good way to save some gates in the logic implementation of the dice. Currently a simple binary counter is used.
    To be honest, it seems that I mistakenly thought of Johnson counters being simple ring counter with one flipflop per state, when in fact they are a nice concept to reduce the number of flipflops needed for a counter by two compary to a ring counter. Even the Wikipedia entry throws Johnson counter and ring counters into one category, which is a bit confusing.
    A fairly nice property of a Johnson counter implementation is that it is possible to implement a counter that comes with a natural sequence length of 6, exactly what we need for the dice. So, in contrast to the binary counter, no additional logic is needed to limit the sequence length.
    Some caveats
    1. The sequence is not in order, since it does not follow binary encoding
    2. The sequence contains "000", which is currently not decoded as a valid face figure on the die.
    3. There are illegal states of the counter, so it has to be initialized
    1) is not really an issue, since we want to randmize the die anyways. So we just accept that the sequence is different. 2) can be solved by inverting the middle bit. See below. 3) requires is to add a reset input. But the NE555 comes with a reset input anyways, so that is almost for free.
    Sequence    johnson counter      middle bit inverted    dice pattern
    Seq1            000                     010                 2
    Seq2            001                     011                 3
    Seq3            011                     001                 1
    Seq4            111                     101                 5
    Seq5            110                     100                 4
    Seq6            100                     110                 6
    Here comes the VHDL implementation of the modified dice:
    architecture main of dice555johnson is
        signal  cnt:    unsigned(2 downto 0);
    begin
         process (clk,n_clk,nreset)
        begin
            if nreset = '0' then
                cnt <= "000";
            elsif rising_edge(clk) then
                cnt <= cnt(1 downto 0) & NOT cnt(2);
            end if;
        end process;
    --  1     2
    --  3  0  3
    --  2     1
    -- Encoding:
    -- 011  0
    -- 000  1
    -- 001  0,1
    -- 110  1,2
    -- 111  0,1,2
    -- 100  1,2,3
    -- drive inverted LEDs
    dice(0) <= NOT cnt(0);
    dice(1) <= '1' when (cnt = "011") else '0';
    dice(2) <= NOT cnt(2);
    dice(3) <= '0' when (cnt = "100") else '1';
    end;
    And here are the design stats after synthesis:
       Number of cells:                  9
         ne_DFF_clear                    3
         ne_NAND3                        2
         ne_NOT                          4
       Chip area for module '\main': 23.000000
     Spice netlist
    .SUBCKT main clk n_clk nrst dice.0 dice.1 dice.2 dice.3
    X0 cnt.1 1 ne_NOT
    X1 cnt.2 dice.2 ne_NOT
    X2 cnt.0 dice.0 ne_NOT
    X3 1 cnt.2 dice.0 dice.3 ne_NAND3
    X4 cnt.1 dice.2 cnt.0 2 ne_NAND3
    X5 2 dice.1 ne_NOT
    X6 clk nrst dice.2 cnt.0 ne_DFF_clear
    X7 clk nrst cnt.0 cnt.1 ne_DFF_clear
    X8 clk nrst cnt.1 cnt.2 ne_DFF_clear
    .ENDS main
    Compared to the stats of the original implementation with binary counter:
       Number of cells:                 18
         ne_DFF                          3
         ne_NAND2                        7
         ne_NAND3                        2
         ne_NOT                          6
       Chip area for module '\main': 39.000000
    Quite impressive! Thanks for the tip, Yann. Will I build this? Probably not, I trust that it would work and I think owning one NE555 based electronic dice is already enough :)
    Edit: Digital simulation output is shown below. Please note, that the dice output is inverted since the LEDs are active low. I found a tiny bug, which is fixed above.
  • Validating Actual Hardware
    Tim01/02/2022 at 04:05 0 comments
    The PCB in all its glory
    Validation
    First step is to test the clock generation. The scope image below shows how the CD4017 generates the nonoverlapping two phase clock (clk and clk_n) from the input clock signal. It appears that the CD4017 is able to operate only up to ~1.3 MHz, so maximum generated output clock is around 300 kHz. This is not a big issue since this is still far beyond the capabilities of NE555 logic.
    Unfortunately, things did not go as smoothly from there. After some debugging I found that I had to raise the operating voltage to 6V for the dice to function properly. The reason for that is the loading of the clock nets when the input to the latches is low. In that case, the output of the CD4017 has to drive a VBE-diode and a 3.3kohm resistor vs ground. Apparently this is too much and we can observe a significant drop in output voltage which which does not allow the NE555 flip flop to switch. (See here for the latch design)
    This is apparant in the scope image below where the high level of the clock signal varies depending on state of the dice.
    Apart from raising the voltage, another fix would be to increase the base resistor value of the pass-gate devices in the latch or introducing some NE555 as clock drivers. Of course, a much cleaner way would be to construct latches from diodes and NE555 like mike has done in his project. But this would raise the number of NE555 further.
    Dice action!
    All said and done, see below for a short clip of the dice operating in NE555 logic!
    And another logic type proven in practice! Would I use it for other designs? Probably not. The area consumption is huge, cost is quite high, power consumption is higher than even RTL (~70 mA for the dice) and it is by far the slowest logic type I ever investigated.
    Unfortunately the version I built based on ANDN2 gates does not seem to work properly. Some more debugging is needed to figure out the root cause.
  • One more thing: NE555 ANDN2 Logic
    Tim12/20/2021 at 23:04 0 comments
    I was made aware of Erics earlier work on NE555 based logic. He actually came up with a pretty neat trick to turn the NE555 into more than just a boring inverter by also using the reset input of the NE555. This results in a logic function based on an AND-gate with one inverted input:
    Image taken from Erics article linked above
    The naming of this type of gate is debatable, but I call it "ANDN2" in my library. It is actually fairly easy to implement this gate in PCBflow as well. I made a version of the dice where I enforced the AND2 and NOT gate to be the only type of logic gate being used:
       Number of cells:                 19
         ne_ANDN2                       10
         ne_DFF                          3
         ne_NOT                          6
       Chip area for module '\main': 31.000000
    Turns out the area is even smaller than withe the Diode/NE555 gates I used before. The reason for that is that no additional space is needed for diodes.
    Unfortunately I had a lot of trouble simulating this logic style with spice. So instead of debugging issues with operating point I decided to take the pragmatic way and turn this into a board to test it rather in hardware.  A rendering of the board is shown below. (I miss-spellt the gate type on the silk screen).
    === Component usage ===
    Component           Count
    pin                 8
    NE555               22
    cap                 22
    npn transistor      6
    resistor            18
    Total:              76
    This logic style requires a slightly higher count of NE555, 22 instead of 21. Not a bad trade-off, because many diodes are saved.
    I should be able to test both versions in about two weeks.
  • Placement and PCB Layout
    Tim12/20/2021 at 22:40 0 comments
    Now that the design topics have been fixed and the circuit works in simulation, we can continue to generate a layout. Again, using PCBflow will output a preliminary PCB with placed components:
    The statistics are as follows:
    Microcell counts:
    ne_NOT      21
    ne_WAND2     7
    ne_TBUF      6
    ne_WAND3     2
    Component usage
    Component           Count
    pin                 8
    NE555               21
    cap                 21
    resistor            27
    diode               20
    npn transistor      6
    Total:              103
    Well, i'd say it's a bit more than a dice with the old role-models of NE555 and CD4017 require, but who are we to judge? Still small enough to comfortably build and test.
    Still some work to do manually: Add the LEDs for the dice, add the CD4017 clock generator footprint, add groundplane and let the autoroute do its (admittedly gut-wrenching) job.
    And here we are, with a nice simulation of the full PCB. A modern rendition of the classic NE555/CD4017 based electronic dice.
    PCBs are being made now and should arrive soon.
  • Finally a use for the CD4017: A clock generator
    Tim12/20/2021 at 22:34 0 comments
    Well, now that the job of the CD4017 in the dice is taken by the NE555, what can we do with the CD4017? Indeed, there is a perfect match for using it has a generator for the two non-overlapping clocks:
    The circuit above will convert a single clock signals into two non-overlapping clocks. Exactly as needed for the NE555 logic. A simulation of this circuit is shown below. The signal in the lower row is the clock input.
    Things are coming together nicely...
  • Simulating the circuit and introducing a two phase clock
    Tim12/20/2021 at 22:31 0 comments
    So far, so good. Unfortunately I ran into some issues here, as the circuit proved quite glitchy during spice simulation. A lot of digging revealed that the setup and hold times of the NE555 latches were somewhat unpredicatable due to the slow speed and under some circumstances the register was not updated during a clock cycle. Each register is implemented by a master-slave flip-flop and simply using an normal and inverted clock signal proved to be unreliable.
    In the end I managed to fix this by introducing a non-overlapping two phase clock, driving master and slave latch of each register separately. The simulation below shows the functionality of the dice, cycling through all six die patterns. The two clock signals (clk and n_clk) are shown at the bottom
  • The Design
    Tim12/20/2021 at 22:26 0 comments
    Bringing the NE555 into the future also means using modern tools. We'll describe the functionality of the dice in VHDL and use PCBFlow to synthesize the digital description into an implementation based on NE555 logic.
    At the same time this will also be the first "real life" test of NE555 logic, as the MCPU is a bit too complex and large to detect basic errors with the logic style.
View all 7 project logs
Yann Guidon / YGDES wrote 01/08/2022 at 09:06 point
https://hackaday.com/2022/01/08/555-timer-on-its-own-in-electronic-dice/
Tim wrote 01/08/2022 at 10:52 point
Wow, that was quick.
Yann Guidon / YGDES wrote 01/08/2022 at 11:18 point
you're in their crosshair.
Yann Guidon / YGDES wrote 01/02/2022 at 18:34 point
NE555 logic is totally wicked but then you swap the duties and turn the 4017 into a clock generator. That's plain naughty and evil !!!
Tim wrote 01/02/2022 at 19:25 point
Some win, some lose. :)
Next, we'll maybe let the LEDs take over everything. I am working on Synthesis of LED-Transistor Logic.
Yann Guidon / YGDES wrote 01/02/2022 at 19:59 point
Before that, I'm curious all you can do with a vanilla 4017...
BTW did you implement a Johnson counter with the 555s, or did you go the whole 10 bits route ?
Tim wrote 01/02/2022 at 20:46 point
It's a binary counter synthesized from VHDL. See first log entry.
I don't thin the CD4017 lends well to generic logic :) Also, way too expensive for my tastes.
Yann Guidon / YGDES wrote 01/03/2022 at 10:22 point
A binary counter ? How sad, a Johnson counter is awesome because it is so easy to decode...
Tim wrote 01/03/2022 at 10:29 point
Actually, it is easier to decode a binary counter to the dice pattern than it is to decode a johnson counter. Takes only two gates. A johnson counter would have required twice the number of DFF plus more gates to decode.
Of course you can always claim that the resistors and diodes used on the original dice with CD4017 don't constitute logic gates :). But when you want to do everything with NE555 logic, it's less efficient.
That said, I don't claim that this is the most efficient way of implementing this functionality with NE555 logic. Surely one could optimize this further by manually optimizing the circuit. The netlist is also attached to the first log, you can give it a try :).
Yann Guidon / YGDES wrote 01/08/2022 at 09:13 point
OK, let's count the gates...
A 10-count counter in binary requires 4 DFF and  10×4-input logic gates.
A 10-states Johnson counter requires 5 DFF and 10×2-input ANDN gates
But....
A dice has 6 codes, damnit, so only 3 DFF for both cases.
I have learned to appreciate Johnson counters and I use them when they are appropriate, such as low-count chasers, or when DFF are practically free. It takes a lot of decoding out of the equation. The constraint of having an even number of outputs is not that much of a problem, in most cases.
Tim wrote 01/08/2022 at 11:12 point
Ok, I have to admit that I thought of a johnson counter as a ring-counter. The implementation with the inverter is pretty nice indeed and allows reducing the number of DFF to three. What is nice, is that the counter will have a natural sequence length of six, so no additional logic is required for that. On the other hand it has some invalid states, so an additional reset input is needed.
If we allows for the sequence to be arbitrary instead of in-order, it seems to be possible to reduce gate count quite significantly!
Thanks for the tip! I will add another log.
Edit: Done, see update
Dr. Cockroach wrote 01/02/2022 at 12:16 point
Fantastic accomplishment :-)
Tim wrote 01/02/2022 at 12:22 point
Thanks! Feels good to complete stuff so I can move on to the next thing ;)
