A quick upgrade of my venerable 20GB iPod from 2005, replacing the spinning hard drive with an SD card reader.
By far the hardest part was just getting the iPod open in the first place! I only had a crappy spudger with me as part of my travel kit (yes, I travel with a spudger) and it took me around 30 minutes just to free the front face.
Make sure the "Hold" switch is in the lock position, indicated by an orange colour. Starting at the top of the device, work the spudger in and around the corners, down the sides. There's five tabs on the left and five on the right which must be pushed in to release.
Be careful, though, because there's a data cable still connected to a little board that has the headphone jack and lock switch. So just open it like a book and there you go!
After disconnecting the data cable, the next step was pulling out the hard drive. I used the spudger to gently push against the plug, being careful to not stress the ribbon.
The next step was to prepare the iPod 4G Converter, which is a rigid ribbon cable and plug that you have to bend in two spots. I was a little wary about bending it too hard and breaking something, but it ended up being okay. In this shot you can also see the crappy spudger I used during this project.
