Firmware update to 2.5.7
A project log for AquaController 2.0
Home automation controller
vadim-teselkinVadim Teselkin 02/17/2022 at 11:130 Comments
Firmware update to 2.5.7:
- Added storage of temperature and PH statistics on the device, when the controller is rebooted, all data is saved.
- For PWM timers, the on-off duration is now set in minutes from 1 - 120 min.
- The temperature limit is set to 78 degrees, to control the temperature of not only water.
- Correction of minor bugs.
Upgrading client version to 2.0.7:
- Optimization of sending and receiving data.
- Ability to disable unused PH2 sensor
- Calibration of PH sensors remembers the entered values.
- Display the firmware version in the device list.
