It works!
A project log for KSP Controller Hardware
Building a set of controllers for Kerbal Space Program including attitude, translation, throttle and hotkey inputs
tobiasTobias 01/08/2022 at 07:130 Comments
After completing the assembly and wiring of the first prototype attitude controller, I put together some arduino code and tried it out in KSP.
The code is fairly simple as it simulates a keyboard with the microswitches of the joystick triggering key presses.
The code still needs a fair bit of work including some form of debouncing and making sure the latency isn't to high
