Technical note: Geiger counter GGreg20_V3 power supply voltage range
A project log for GGreg20_V3 Ionizing Radiation Detector
The GGreg20_V3 Ionizing Radiation Detector is a new-generation ready-to-use device with an SBM-20 Geiger tube and pulse counting output
iot-devices-llcIoT-devices, LLC 03/04/2023 at 21:320 Comments
The Geiger counter module GGreg20_V3 has built-in protection against reverse polarity. This function is realized by means of a Schottky diode.
The module can operate in two modes:
(1) with protection against reverse polarity;
(2) with an extended range of power supply voltage.
Read full article:
https://iot-devices.com.ua/en/technical_note_supply_voltage_range_geiger_counter_ggreg20_v3/
