Technical note: How to calculate the conversion factor of CPM to μSv/h for DIY Geiger counter project with J305 GM-tube
2 days ago • 0 commentsWe have already made a similar publication for the SBM20 Geiger tube. This time we bring to your attention an article dedicated to the equally popular J305 GM-tube made in China.
Read the full article:
Easy Link - bookmark or share:
Changes in ESPHome configuration validation – Pin Reuse validation
01/05/2024 at 17:01 • 0 commentsRecently, the ESPHome firmware has been changed to prevent the same controller I/O ports from being reused to create different entities.
These updates in ESPHome version 2023.12.0 also affected the examples developed by our company for the GGreg20_V3 Geiger counter ionizing radiation detector module.
According to the user’s request (https://github.com/iotdevicesdev/GGreg20_V3-ESP32-HomeAssistant-ESPHome/issues/2) regarding the repository for GGreg20_V3-ESP32-HomeAssistant-ESPHome, we have made the necessary updates to the configuration YAML file.
Now this example will work properly with the new ESHome configuration validation and you will be able to upgrade to newer versions of ESPHome without any problems.
We also plan to update other repositories with this issue.
Read the full article with examples and solutions here:
IF BlackFriday() OR CyberMonday() THEN Sale(%);
11/23/2023 at 19:16 • 0 commentsCyber Monday until 30.11!
We launch “Cyber Monday” campaign from 24.11 to 30.11 and set 10% discount when buying any of our modules on iot-devices.com.ua and Tindie and Etsy trading platforms.
Pay attention to our charity product GGreg20_ES
As well as our popular modules:
- GGreg20_V3 radioactive particle detector with J305 Geiger tube: ggreg20_v3
- DCDC_3V3_400V_V1 module is a high voltage 3.3V DC to 400V converter: dcdc_3v3_400v_v1.
- I2CUI4_V1 User Interface – I2C module with 5-button keypad: i2cui4_v1
Source:
https://iot-devices.com.ua/en/cyber-monday-promotion-till-30-11-en/
SBM20 GM-tubes are still available on Etsy to order with GGreg20_V3
11/19/2023 at 08:44 • 0 commentsHurry up if you want to order GGreg20_V3 with SBM20 tube.
Because our Tindie and website are out of these tubes (as of 11/19/2023), but they are still available on Etsy. At the same time, we also recommend ordering with J305, which is currently available in all stores.
Where to order with SBM20 or J305:
https://go.iot-devices.com.ua/ggreg20_v3_etsy
Or with J305 only:
- Tindie: https://go.iot-devices.com.ua/ggreg20_v3_tindie
- Website: https://go.iot-devices.com.ua/ggreg20_v3
Geiger counter GGreg20_V3 module is already on Etsy store
11/06/2023 at 21:58 • 0 commentsNovember 06, 2023, Kyiv, Ukraine.
Dear users, customers and partners!
We are pleased to announce that with the launch of Etsy Payments service in Ukraine, we immediately opened our own official store on this wonderful platform for DIY.
Now you can order the company’s products on Etsy or Tindie, as well as on our website. With the launch of Etsy Payments in Ukraine, our visitors and regular customers can choose any convenient and secure payment method such as bank cards, PayPal, etc. As an added bonus, Etsy protects transactions between consumers and traders within the platform.
Geiger counter GGreg20_V3 is also available for order in our Etsy shop!
Best regards,
Team IoT-devices
GGreg20_V3 and ESP12.OLED_V1 in the project of KPI specialists
08/22/2023 at 13:52 • 0 commentsAn interesting work by experts from the Kyiv Polytechnic Institute describes software methods for analyzing streaming data, in particular, for analyzing radiation pollution.
The article analyzes open data on radiation air pollution in the city Kyiv and visualized the data using analytical tools of the Python programming language.
Source:
https://iot-devices.com.ua/en/ggreg20_v3-esp12-oled_v1-kpi-project/
Our GGreg20_V3 Geiger counter modules live on gmcmap.com
07/18/2023 at 20:48 • 0 commentsGreat news!
Several more customers have connected to the gmcmap.com service radiation detectors based on our GGreg20_V3 radioactive particle detector module.
Read the full story here:
Easy Links
go.iot-devices.com.ua/geiger-counter
go.iot-devices.com.ua/geiger-counter-emulator
go.iot-devices.com.ua/i2c-keypad
go.iot-devices.com.ua/esp8266-mcu-board
go.iot-devices.com.ua/high-voltage-converter
GGreg20_V3 with Raspberry Pi Pico W under Home Assistant with ESPHome firmware config example
07/18/2023 at 20:25 • 0 commentsWe’ve been planning to post a GGreg20_V3 configuration example for the Raspberry Pi Pico W since ESPHome started supporting this wonderful controller with wireless support. But after users started making projects for RPi with GGreg20_V3, and after Tom’s Hardware wrote about a project using Pico W, we also made our own full-featured configuration example.
Easy Links
Geiger-Muller tubes: Comparison of SBM20, J305 and LND712
07/18/2023 at 19:04 • 0 commentsWe understand very well the difficulties of choosing for radio amateurs who have to choose between different options, including tubes, when ordering a product.
When we developed GGreg20 in 2020, we did not know anything about these things at all.
Now we can share our company’s experience with anyone who needs help or is just looking for more information.
https://iot-devices.com.ua/en/comparison-of-geiger-muller-tubes-sbm20-j305-and-lnd712/
Technical note. How to calculate the conversion factor for Geiger tube SBM20
07/18/2023 at 19:02 • 0 commentsThere are a lot of publications on the Internet on how to convert CPM (Counts per Minute) obtained from a Geiger tube to radiation levels.
However, despite the wide coverage of this topic on various forums and a wide range of examples with code for various programming languages, we had to understand the topic deeper than we wanted to in order to be able to properly calculate the conversion factor for Geiger tube SBM20 from CPM to absorbed dose of radiation μSv/h and configure the conversion in our own products and make an example calculation for everyone.
