OctoCore 2.1 - & PCBway sponsorship
A project log for Rosmo robot
Modular open hardware robot for uROS2 & Microblocks
samukSamuk 03/03/2022 at 14:050 Comments
Following up on OpenCore1.0 which was just a carrier board for an ESP32-DevC-v4 board.
We've been doing a bit of work on an onboard ESP32. This includes 8x servo's to support a #ottodiy or #stackchan use case
 We're calling this board Octocore & the files are here.
The board is intended to support OpenGarden sensors a 1.54" or 2"  screen, an HCS404 sensor as well as the M5stack modules
If it works as expected we hope it will be useful to people making small robots
It's untested at present, but thanks to the kind sponsorship of PCBway we have 5x test boards being made soon.
If you want to check out what PCBway offers then check here
