camera_mounts.step
STEP file if you want to adapt the files for your components.
step - 292.12 kB - 03/18/2022 at 10:32
Download
motor_mount.3mf
Motor mount for standard FPV drone motors.
3mf - 196.52 kB - 03/18/2022 at 10:32
Download
wing_mount_A.3mf
Bottom part of the wing mount. It holds the nut and should be glued into the fuselage.
3mf - 4.66 kB - 03/18/2022 at 10:32
Download
wing_mount_B.3mf
Serves as a guide rail for the nylon screw.
3mf - 48.32 kB - 03/18/2022 at 10:32
Download
canopy_hinge_A.3mf
Canopy part of the hinge mechanism.
3mf - 12.59 kB - 03/18/2022 at 10:32
Download
canopy_hinge_B.3mf
Fuselage part of the hinge mechanism.
3mf - 9.53 kB - 03/18/2022 at 10:32
Download
fpv_camera_mount.3mf
Bottom facing FPV camera mount, fits the Cadx EOS2.
3mf - 34.26 kB - 03/18/2022 at 10:32
Download
elevator_horn.3mf
Bigger elevator servo horn for extra rigidity.
3mf - 8.48 kB - 03/18/2022 at 10:32
Download
battery_connector_holder.3mf
Simplifies the battery swaps.
3mf - 13.00 kB - 03/18/2022 at 10:32
Download
battery_terminal_clip.3mf
Extra precaution to prevent the Li-Ion cells from short circuiting.
3mf - 9.26 kB - 03/18/2022 at 10:32
Download
battery data.xlsx
Excel sheet with information about Li-Ion cells and calculations for flight time, range and speed.
sheet - 28.81 kB - 01/27/2022 at 18:45
Download
static thrust data.xlsx
Raw static thrust and power data for all the tests I’ve made.
sheet - 71.11 kB - 01/26/2022 at 18:04
Download
Articles on components.txt
Further articles and information on components.
plain - 603.00 bytes - 01/23/2022 at 16:27
Download
plain - 462.00 bytes - 01/22/2022 at 11:49
Download
