Experiment No.1
A project log for Self-made EL segment displays
How to make your own display with almost any configuration just using a paintbrush
artem-kashkanovArtem Kashkanov 12/22/2021 at 19:560 Comments
In Experiment One, I just decided to test the technology's viability.
To do this, I mixed barium titanate in an alkyd yacht varnish in a 1: 1 ratio and applied it with an airbrush in a thin layer on a PCB strip. Then I applied a layer of a mixture of blue phosphor EL-455, again in alkyd yacht varnish in a ratio of 2: 1, and then glued conductive glass on top with a drop of alkyd varnish. This sample No. 1 worked, although, after a week of lying on the shelf, it darkened noticeably and almost completely lost its brightness. In attempts to squeeze at least something out of him, he burned out and will never shine again.
