NeoDigito: Modular 7-segment RGB display
Simplify the show of numbers, text and colors with a 7-segment display, using a single control pin, making it fun to use.
Public Chat
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
NeoDigito are the alternative for conventional seven-segment displays and LED matrix, mainly for big size displays. With the advantage of having a better appearance and being easy to use, as they are built with the WS2812B controller, used in LED strips, which works with a single pin, making fun to display numbers, text and colors. You can give a distinctive look to your projects, regardless you are a maker or a professional.
The idea was born in a project that needed to show a lot of numbers and the capability to change colors depending on the value. This is our Open Source solution and we want to share it with you.
Please support the campaign in Kickstarter.
