vario_components.jpgComponent side of the strip boardJPEG Image - 253.15 kB - 01/12/2022 at 22:49 |
veroboard_back.jpgVeroboard, showing tracks to be removed and holes to be drilledJPEG Image - 186.61 kB - 12/31/2021 at 00:57 |
Vario_Customisation.pdfInstructions for installing a PC terminal program, connecting the Vario and modifying the stock configuration sensitivity and excitability level.Adobe Portable Document Format - 469.53 kB - 12/30/2021 at 22:26 |
VARIO_BOX.stl3D print STL file for enclosure parts as single file (you may need to separate the parts to print individually.Standard Tesselated Geometry - 584.26 kB - 12/30/2021 at 22:16 |
Vario_Circuit.jpgSchematic for the variometerJPEG Image - 102.12 kB - 12/30/2021 at 22:04 |
AUDIO_VARIOMETER_SOURCE.zipArduino IDE code for the variometerx-zip-compressed - 6.88 kB - 12/30/2021 at 22:03 |
