Theory of operation
A project log for Resolver to CAN, I2C
Drives a resolver and returns the rotor angle at an update rate of 10kHz
px-protoypesPX Protoypes 01/03/2022 at 16:100 Comments
The resolver angle is read as follows:
The firmware has various monitoring functions via a USB serial port as well as an automatic calibration routine to determine the resolver primary to secondary ratio for the best accuracy as well as the phase delay of the amplifier.
