Project journal
A project log for STEbus Z180 slave board (IPI)
A 64180 or Z180 communicates with the STEbus through a one-byte port.
keithKeith 02/05/2023 at 16:290 Comments
2023-02-04
Populated with PAL chips. Both memory chips have A0 to 13, enough for 16K devices. Address, Data, /CE, /RD and /WR pins are toggling.
No sign-on message. :-(
Serial data from terminal appears at the CPU pin RXA0, and CTS0 toggles as driven by RTS, but no activity on TXD0.
There is a good chance that this was a non-working board used for exhibition display purposes.
This will take a bit of work to diagnose. I'll need to analyse the firmware. I started disassembling it. I need to write some self-diagnostic code.
