Universal retro computer emulator based on Raspberry Pi PICO
This board can run retro computer machine emulator MCUME
and is also compatible with Miroslav Nemecek PicoVGA
Required components
| Component | Pcs | Description | Note |
| Raspberry PICO | 1 | main green board | - |
| DTS63K | 37 | tactile switch 7mm height, 1N | Or another 1N force is very comfortable to press |
| 2K 0603/ 0805/ TH Ø1.8x3.2mm | 2 | Resistor | for VGA |
| 1K 0603/ 0805/ TH Ø1.8x3.2mm | 2 | Resistor | for VGA |
| 470R 0603/ 0805/ TH Ø1.8x3.2mm | 2 | Resistor | for VGA |
| 820R 0603/ 0805/ TH Ø1.8x3.2mm | 1 | Resistor | for VGA |
| 390R 0603/ 0805/ TH Ø1.8x3.2mm | 1 | Resistor | for VGA |
| 82R 0603/ 0805/ TH Ø1.8x3.2mm | 1 | Resistor | for VGA |
| DSUB15 FEMALE | 1 | Connector Female | for VGA monitor |
| DSUB9 MALE | 1 | Connector Male | for Joystick |
| SD card SMD | 1 | micro SD car reader | |
| LD-PZPN-3510 | 1 | PIEZO | PIEZO sound beeper or another |
| JS202011CQN C&K or MSS-2235 NINIGI | 1 | Side Switch | For power off (RetroVGA work without) |
MCUME emulators are very basic, no save state, no configuration, only select games from card.
Not all games works, there can be some screen issues, flashing sprites, freezes, unexpected resets
Game console systems supported:
- Atari 2600
- Odyssey/Videopac
- Colecovision
- Atari 5200
Computer systems supported:
- Zx81
- Zx spectrum
- Atari 800
- C64
bobricius
land-boards.com
Jenny List
Michal
Which uSD card socket was used in the design? I had a similar one but I can't get it to work so need to order the right one.
