I found a fitting frame at IKEA. With the original passe-partout and a grey background, the CS 555 is now ready for presentation. I drilled holes for the legs through the base and fixed them with hot glue. Now a can run it from outside using alligator clips.
Also with a schematic for a test circuit on the back side.
Now I consider this project finished.
MaBe42
