BasePlate1.3mfBase plate 3MF with snap fit bracket for a 6mm momentary push button, a small LiPo battery and a TP4056 charging module (needs RetainingClip.3mf and a knurled insert for screw). Tripod mount with a 1/4"-20 screw & knurled insert.3mf - 34.04 kB - 01/05/2022 at 01:55 |
LightPanel1.3mfPrintable bracket for button type NeoPixels. Print two (one mirrored). Solder NeoPixels in a strip.3mf - 65.49 kB - 01/05/2022 at 01:55 |
TopShell1.3mfThe enclosure. No supports required, but might help with the opening for the PIR. Heat set knurled inserts to secure light panels (M3) and base plate (M4).3mf - 69.35 kB - 01/05/2022 at 01:55 |
3mf - 5.30 kB - 01/05/2022 at 01:55 |
MPEG-4 Video - 7.84 MB - 01/05/2022 at 01:54 |
