Your all-in-one 5G and 2.4G WiFi toolkits!
Now it supports,
- Colorful TFT LCD Menu
- 5G & 2.4G WiFi Scanner
- 5G & 2.4G WiFi Analyzer
- 5G & 2.4G WiFi Sniffer (WIP)
- Simple MQTT client (WIP)
This project is based on Ameba A1 Pico (RTL8720DN from Realtek), it has dual-core ARM Cortex-M processors clocked at 20MHz and 200MHz respectively, equipped with 5G & 2.4G WiFi as well as BLE5.0, 512KB SRAM, 2MB Flash, thus its able to house many applications into the single firmware on the flash. With the TFT LCD Menu feature, you can easily add your own application and start hacking~
SimonXi
myembed
Frank Lin
Jean-Pierre Cocatrix
