Hackaday.io Hackaday.io
Recently Updated Most Likes Newest Project Lists
Courses Tutorials Events Hackerspaces Profiles Hackaday.com Tindie Marketplace
Sign up Log in
BitPiRat Computer (GEN2.0)
First dedicated RPi platform for full node Bitcoin and Lightning Network
MirkoMirko
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
3.6k views
12 comments
46 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 11
    • View all
  • Instructions 0
  • Discussion 12
View Gallery
3.6k
12
46
31
Team (1)
  • MirkoMirko
Join this project's team
  • Bitpirat GEN2.0
  • Twitter
completed project
hardware
raspberry pi nvme
This project was created on 01/06/2022 and last updated 4 months ago.
Description
This is a dedicated, compact platform for cryptocurrency networks, such as for bitcoin full nodes (RunCitadel, RaspiBlitz, RoninDojo) and for other network applications, such as: micro web server, PLEX media server, NAS drive.
Technical specification:
- RPi Pi Compute Module 4 (CM4) support (both versions with and w/o eMMC - Lite version),
- full 2280 M.2 M-key socket dedicated for NVMe PCIe SSD drives (1TB size or more),
- microSD card slot,
- Gigabit RJ45 port (GbE),
- USB-C (USB 2.0) for CM4 module flashing (power + data),
- 2-pin 5VDC header for fan (GPIO controlled. open-collector driver) and 4-pin Molex socket for fan with PWM control (EMC2301 controller with I2C),
- MIPI DSI port for LCD panel,
- Qwiic port (I2C interface),
- PCM audio port,
- User LEDs,
- MiniHDMI video output (debug),
- overvoltage and overcurrent protected,
- slide switch for boot/flash mode.
Project Logs
Collapse
  • User interface
    Mirko • 01/12/2022 at 09:31 • 0 comments
    GPIO pin assignment:
    GPIO port - pin header:
    Fan #1 circuit:
    Fan #2 circuit:
    PCM Audio port:
    USER LEDs:
    Buzzer:
  • User interface
    Mirko • 01/12/2022 at 09:27 • 0 comments
    Fan #1 circuit:
    Fan #2 circuit:
    PCM Audio port:
    USER LEDs:
    Buzzer:
  • Future plans (GEN2.1 and GEN3.0)
    Mirko • 01/06/2022 at 02:50 • 1 comment
    There are plans to update this project and to implement new features (roadmap for 2022):
    GEN2.1:
    - mechanical improvements (new PCB dimensions, updated mounting holes position),
    - updated GPIO port to be compatible with future designed LCD front-panel,
    - designed dedicated push-button controller and power management unit (PMIC).
    GEN3.0:
    - PoE power supply standard,
    - LCD front-panel with 3.5" screen and touch pad,
    - fingerprint sensor,
    - NFC reader,
    - 12VDC power supply,
    - 2-port USB hub.
  • BitPiRat during testing
    Mirko • 01/06/2022 at 02:38 • 0 comments
    #BitPiRat during testing...
    CM4 & CM4 Lite - OK
    MiniHDMI - OK
    Qwiic OLED - OK
    User LEDs OK
    Buzzer - OK
    ETH - OK
    M.2 NVMe SSD 2280 - OK
    PWM fan EMC2301 - OK
    USB 2.0 - OK
    MIPI DSI - OK
    It seems that so far all the features are working 100%
    ImageImageImageMIPI DSI 800x480 IPS LCD & Qwiic OLED I2C 128x64:
  • BitPiRat project - short promo video
    Mirko • 01/06/2022 at 02:36 • 0 comments
    We are working with the RunCitadel developers to offer the next-gen platform for full node bitcoin and Lightning network.
    https://twitter.com/i/status/1471899920378564613
  • Testing LCD panels
    Mirko • 01/06/2022 at 02:32 • 0 comments
    #BitPiRat during testing LCD SPI screens.
    Waveshare LCD module: 1.3", 240x240 pix, IPS matrix, ST7789 controller.
    You can connect lot of different LCD/OLED screens by using interfaces such as: I2C, SPI, MIPI DSI, or MiniHDMI.
    So you can also run OS @RaspiBlitz @mynodebtc @RoninDojo
    2", 320x240 pix, LCD SPI, ST7789, Waveshare.
    Pictures rescaled to the full screen.
  • During testing by other users
    Mirko • 01/06/2022 at 02:30 • 0 comments
  • Installed crypto distro - RunCitadel
    Mirko • 01/06/2022 at 02:29 • 0 comments
    During synchronizing bitcoin blockchain and long-term functional tests.
    RunCitadel:
    https://github.com/runcitadel
    https://twitter.com/runcitadel
    Setup:
    - CM4 Lite module with 8GB RAM,
    - 1TB NVMe SSD drive (WD Blue SN550 Series),
    - 64GB microsd card (SanDisk Extreme),
    - GbE,
    - 5.1V supply
    OK, 100%, fully synchronized.
    Citadel updated to v0.5.17.
    Node works stable and without any issues so far.
  • 3D STEP model (PCBA)
    Mirko • 01/06/2022 at 02:25 • 0 comments
    https://github.com/mfolejewski/BitPiRat-GEN-2.0/tree/main/3D_STEP_PCB
    ScreenshotScreenshotScreenshotScreenshotScreenshotScreenshot
  • Asembled PCB board
    Mirko • 01/06/2022 at 02:24 • 0 comments
    ScreenshotScreenshotScreenshotScreenshotScreenshotScreenshotScreenshotScreenshotScreenshotScreenshot
View all 11 project logs
Log In/Sign up to comment
Sign up with Github
OR
Paul wrote 04/29/2022 at 02:53 • point
I see that a case is possible for this design. But is a more dense setup in the works? It would be nice to mount this like a blade in a 10 or 19-inch rack.
Manny wrote 04/06/2022 at 16:08 • point
I've been looking for a board with support for full 2280 m.2.  will be watching for its availability.
Danny Jul wrote 02/23/2022 at 19:13 • point
Why not POE as early as possible? I was already wondering about the lack of POE when I saw GEN 1, which otherwise looked nice.
CoolBuster999 wrote 01/27/2022 at 21:40 • point
When is your plan to produce?
Mirko wrote 01/31/2022 at 14:03 • point
Q2/2022 will be introduced on the market as a fully commercial product
CoolBuster999 wrote 01/31/2022 at 14:19 • point
What will be the anticipated price?
Albert wrote 01/26/2022 at 15:31 • point
With POE, this would be perfect for almost all of my uses!
Mirko wrote 01/27/2022 at 07:29 • point
Future plans
Next gen3.0 should have PoE option.
Gravis wrote 01/12/2022 at 01:10 • point
Don't make this.  Seriously, you're just polluting for profit.  It doesn't do anything except pollute.
CoolBuster999 wrote 01/27/2022 at 21:35 • point
It does have use cases and can be used for thing other than crypto. It sounds like you have a personal conflict with crypto related projects without doing any research.
Please do not make comments like this, seriously, pollution for comments is the worst. It is after all double pollution, both pollution for energy to the device used to make the commenting, and pollution of the comment track. In addition, comment pollution makes pollution for profit look even more attractive.
Hacking the pinout for a salvaged LCD replacement for PC LED status indicators from an old Fujitsu Siemens Celsius PC, Core 2 Duo/Quad era.
Project Owner Contributor
Hacking the ADT-S007001A-03 LCD module pinout
Non-ICENon-ICE
First in the world dedicated RPi platform for full node bitcoin (BTC) and Lightning Network
BitPiRat Computer (GEN1)
MirkoMirko
An ongoing project to add entertainment, bells, whistles and quality of life improvements to the car.
Car of the future!
jDubjDub
A open source transparent watch, ultra-thin, BLE, 20mm strap
Open Source Transparent Watch - T1
ModularModular
Going up?
© 2022 Hackaday
Yes, delete it Cancel
You are about to report the project "BitPiRat Computer (GEN2.0)", please tell us the reason.
Send message
Remove Member
