First dedicated RPi platform for full node Bitcoin and Lightning Network
GPIO pin assignment:
GPIO port - pin header:
Fan #1 circuit:
Fan #2 circuit:
PCM Audio port:
USER LEDs:
Buzzer:
Fan #1 circuit:
Fan #2 circuit:
PCM Audio port:
USER LEDs:
Buzzer:
There are plans to update this project and to implement new features (roadmap for 2022):
GEN2.1:
- mechanical improvements (new PCB dimensions, updated mounting holes position),
- updated GPIO port to be compatible with future designed LCD front-panel,
- designed dedicated push-button controller and power management unit (PMIC).
GEN3.0:
- PoE power supply standard,
- LCD front-panel with 3.5" screen and touch pad,
- fingerprint sensor,
- NFC reader,
- 12VDC power supply,
- 2-port USB hub.
#BitPiRat during testing...
CM4 & CM4 Lite - OK
MiniHDMI - OK
Qwiic OLED - OK
User LEDs OK
Buzzer - OK
ETH - OK
M.2 NVMe SSD 2280 - OK
PWM fan EMC2301 - OK
USB 2.0 - OK
MIPI DSI - OK
It seems that so far all the features are working 100%
MIPI DSI 800x480 IPS LCD & Qwiic OLED I2C 128x64:
We are working with the RunCitadel developers to offer the next-gen platform for full node bitcoin and Lightning network.
#BitPiRat during testing LCD SPI screens.
Waveshare LCD module: 1.3", 240x240 pix, IPS matrix, ST7789 controller.
You can connect lot of different LCD/OLED screens by using interfaces such as: I2C, SPI, MIPI DSI, or MiniHDMI.
So you can also run OS @RaspiBlitz @mynodebtc @RoninDojo
2", 320x240 pix, LCD SPI, ST7789, Waveshare.
Pictures rescaled to the full screen.
During synchronizing bitcoin blockchain and long-term functional tests.
RunCitadel:
https://twitter.com/runcitadel
Setup:
- CM4 Lite module with 8GB RAM,
- 1TB NVMe SSD drive (WD Blue SN550 Series),
- 64GB microsd card (SanDisk Extreme),
- GbE,
- 5.1V supply
OK, 100%, fully synchronized.
Citadel updated to v0.5.17.
Node works stable and without any issues so far.
I've been looking for a board with support for full 2280 m.2. will be watching for its availability.
Why not POE as early as possible? I was already wondering about the lack of POE when I saw GEN 1, which otherwise looked nice.
Q2/2022 will be introduced on the market as a fully commercial product
Don't make this. Seriously, you're just polluting for profit. It doesn't do anything except pollute.
It does have use cases and can be used for thing other than crypto. It sounds like you have a personal conflict with crypto related projects without doing any research.
Please do not make comments like this, seriously, pollution for comments is the worst. It is after all double pollution, both pollution for energy to the device used to make the commenting, and pollution of the comment track. In addition, comment pollution makes pollution for profit look even more attractive.
I see that a case is possible for this design. But is a more dense setup in the works? It would be nice to mount this like a blade in a 10 or 19-inch rack.
