DIY 4 in 1 BLDC ESC 30A 3~4S
DIY BLHeli / SimonK 8-Bit ESC
On my way for building my own quad UAV, here's my second attempt on designing a 4 in 1 ESC.
Hopefully covering and fixing all the design flaws I've had in earlier prototypes.
It's been all designed around easy to source components, considering fair to normal soldering skills without sacrificing any features available in commercial 8-bit ESCs.
FEATURES:
- 30A 3~4S / No i/p caps
- BLHeli / SimonK compatible
- OneShot125 compatible
- Flashing over RX or over SPI
Schematic is available in the attached SEEED Fusion Gallery link.
UPDATE!!
I've just received the first batch of PCBs and I'm honored to share the awesome experience I had with Seeed Studio one-stop manufacturing/assembly service! Considering the superior PCB quality and very smooth ordering, delivery process. It all took me less than 10 mins to place my order.
Its also possible to order assembled PCBs here "https://www.seeedstudio.com/prototype-pcb-assembly.html"
  • 4 × ATMEGA8u Microprocessors, Microcontrollers, DSPs / ARM, RISC-Based Microcontrollers
  • 4 × FORTIOR FD6288t 3 Phase FET driver
  • 24 × WSD30140 N-FET
  • 2 × AMS1117-5 Linear regulator
